nipple broked
Old Feb 16, 2005 | 12:21 PM
98_civic_dude's Avatar
Default nipple broked
sup guys. my buddy broke the nipple of the map sensor. so we took the bottom of the map sensor out and there was a really,really,really tiny silver tube. we both put the tube with the check valves over that small tube on the bottom and sealed it with silicon. will this work??will it leak?? we sealed it pretty good with silicon. just want to know if this will break the map sensor off when he hits boost. also, wut did you guys do about the nipple that goes to where the map sensor used to be? my buddy's using a y7 manifold and the nipple keeps falling off because the map sensor is on the back, causing his car to go into limp mode. wut should we do about that?
reddysol
Sep 8, 2007 10:57 AM
methos713
Jun 11, 2007 12:43 PM
