what size intercooler piping 3 or 2.5
Re: what size intercooler piping 3 or 2.5 (turboedc2)
well 70mm is approximately 2.75" so right in between. I'm looking to make over 600whp and was told by a very reliable source to use 2.5" intercooler piping. I mean the inlet and outlets on my intercooler are only 2.5" so why go 3"?
Re: what size intercooler piping 3 or 2.5 (Lucky_Smurf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucky_Smurf »</TD></TR><TR><TD CLASS="quote">well 70mm is approximately 2.75" so right in between. I'm looking to make over 600whp and was told by a very reliable source to use 2.5" intercooler piping. I mean the inlet and outlets on my intercooler are only 2.5" so why go 3"?</TD></TR></TABLE>i dont mind going 2.5 but i see alot of people with big power with 3 so i was curious
Re: what size intercooler piping 3 or 2.5 (808 DB8)
me too... I'm trying to get around 500hp and i'm running 2.25 pipings only. My turbo outlet is 2.5 then it goes to 2.25 piping and to a 2.75 intercooler then back to 2.25 and to the throttle body. (stock gsr) Do i need to upgrade my pipings?
Re: what size intercooler piping 3 or 2.5 (tRaCeBuStAbUsTeR)
it depends how thick your fmic is if its 3.5 inches then i would run 3 inch on the tb side.
Re: what size intercooler piping 3 or 2.5 (jdmhonda)
im running the precision as1025. it should be a 3.5in thick. Would it be fine running 2.25 piping on the turbo side and maybe 2.5 or 3 on the throttle body side?
Modified by tRaCeBuStAbUsTeR at 12:15 AM 6/18/2005
* B A N N E D *
it all depends on you turbo also....if you already have the problem of lag from such a big turbo.. you should indeed run a smaller size piping to speed up the air to the intercooler .. and form there you can go to 2 1/2 ive always went 2.25 to 2.5 piping on all my turbo cars and turbo cars i had to fabricate the intercooler piping
what about running 2.25 in the turbo side and 2.5 on the throttle body side? Would that be better then 2.25 all the way around?
