questions about install on a jrsc
Old Jun 16, 2005 | 11:19 AM
SneezR's Avatar
Default questions about install on a jrsc
98 gsr, I will be using Hondata s200 w/ boost
what is #1 plug for?
#2 is that the correct way to attach the IAB? Do I need to attach any vaccum lines?
#3 is this hose replaced at all?
#4 is this hose replaced at all?
(This is how my project currently sits)
is there anything else you notice that doesn't look correct, or needs to be done before I attach the blower to the manifold?
Old Jun 16, 2005 | 02:24 PM
mattssi's Avatar
I think plug 1 may be for your IAT
Old Jun 17, 2005 | 11:13 AM
Adi Radoncic's Avatar
On Fire!
Default Re: questions about install on a jrsc (SneezR)
#1 plugs into one of the sensors on the factory black vacum box
#2 Is a chunt valve
#3 Coolant line feeding the heater core so you heat inside the car
#4 Coolant out for heater core
Both #1 and #2 won't be needed after you do hondata..
Old Jun 17, 2005 | 12:41 PM
enginetiks's Avatar
#3 heater hose is supposed to be relaced(do not ruse the metal pipe)...
#4 I usually relace this hose as well
Leave the IAB plugged in...do not connect any hoses to it
#2 appears to be the plug for your iac valve(Not sure...gotta check the wire colors)...I dont know what they plugged it into, but generally on a jrsc kit for a gsr you have to extend those wires to reach the iac valve(the kit actually comes with a premade extension harness)
Old Jun 17, 2005 | 01:23 PM
cinq's Avatar
Default Re: questions about install on a jrsc (newgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">#1 plugs into one of the sensors on the factory black vacum box
#2 Is a chunt valve
Both #1 and #2 won't be needed after you do hondata..</TD></TR></TABLE>
Correction..#4 is for Idle Air Control Vavle
turboHondaWesJ
Dec 22, 2012 07:44 AM
ndiehm
Mar 23, 2012 05:03 PM
Jdmtuned
Apr 23, 2009 11:00 AM
carbonlaced
Mar 16, 2006 10:28 AM
BringIT
Dec 1, 2003 11:35 AM
