is overfilling ok?
Old Jun 14, 2005 | 06:43 PM
fanta!'s Avatar
Default is overfilling ok?
is it ok to overfill your oil a little bit? im talking about 2-3capfulls just in case of oil starvation? like before the track or a race
Old Jun 14, 2005 | 06:46 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: is overfilling ok? (father)
ok,what difference would 3-4oz of oil make?
Old Jun 14, 2005 | 07:02 PM
adseguy's Avatar
Default Re: is overfilling ok? (wantboost)
I went 3/4 of a quart over once. I'm sure it's gonna be fine . you can even go a little under if you wanted too
Old Jun 14, 2005 | 07:03 PM
fanta!'s Avatar
i guess itd help if i metioned what cap i was using (not talking about the caps on the bottle of oil)...
anywho is it ok to do so?
Old Jun 14, 2005 | 07:04 PM
wantboost's Avatar
Who is Mr Robot?
id say you are fine as long as it doent interfere with your oil return
Old Jun 14, 2005 | 07:12 PM
Muckman's Avatar
Moderator in Chief
2 or 3 cap fulls?! are you serious?! cry me a river.
Old Jun 14, 2005 | 07:17 PM
civiccpedx's Avatar
Default Re: is overfilling ok? (Muckman)
your fine, the only thing you should be worried about is prolly like a full quart extra, that could cause pressure to build up
Old Jun 14, 2005 | 07:18 PM
Bailhatch's Avatar
Default Re: is overfilling ok? (civiccpedx)
I never even bring it up to the full dot...do i need like 13 capfulls?
Old Jun 14, 2005 | 07:27 PM
Def's Avatar
Def
Default Re: is overfilling ok? (Bailhatch)
I've run about 3/4 quart religiously on my old M3 with no problems. That car would oil starve easily, and a little bit more oil is much better than a dead engine.
Run a baffled pan on my SR now, so no problems there!
Old Jun 14, 2005 | 09:17 PM
.::Lee::.'s Avatar
2-3 capfuls is no big deal. That is probably about the same amount that would fill your oil lines. However too much overfilling will destroy your motor and will turn a perfectly straight rod into, well a not so straight rod!
Now the question is why?
Old Jun 14, 2005 | 10:04 PM
turtle-eg's Avatar
2-3 cap fulls won't hurt, but it wouldn't help either.... it's too little to make a difference. If you have a baffle in your oil pan, you should be fine.
ramboPandA
Oct 4, 2013 10:20 PM
Budget Racer
29
Mar 29, 2008 12:05 PM
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
rota power
Aug 13, 2006 11:44 AM
eldorko86
10
Sep 4, 2005 06:35 AM
