Mercedes T3. Wierd Internal wastegate. How to lower boost?
First of all, lets say i know how anoying it is when a n00b asks a question that has been answered a million times, but, look at this wastegate, i got this turbo real cheap and it suits my needs pretty well. So, anyone know stock pressuere, im guessing 8 psi, and how to lower it?
And the Wastegate output is not blocked off in those pics, it diverts the exhaust out the primary outlet from before the exhaust turbine.
TIA
Pics are not mine, stole them of someone, if you rather i take them off just let me know.
TIA
B A N N E D
Re: Mercedes T3. Wierd Internal wastegate. How to lower boost? (Blindstuff)
damn sorry i cant help you but wow thats going on a H22a huh? nice nice haha that will spool pretty fast
there should be a ring clip on top of the wastegate that you can pull out with needle nose pliers. Do that and I think there's a nut or screw inside that you use to adjust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Los Angelino »</TD></TR><TR><TD CLASS="quote">damn sorry i cant help you but wow thats going on a H22a huh? nice nice haha that will spool pretty fast</TD></TR></TABLE>
Pics arent mine, its going on a DOHC ZC, i wish i had a H22a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccidentproWn »</TD></TR><TR><TD CLASS="quote">there should be a ring clip on top of the wastegate that you can pull out with needle nose pliers. Do that and I think there's a nut or screw inside that you use to adjust.</TD></TR></TABLE>
Lemme check today
Anyone else, i know there is people who have used this turbo
Lemme check today
Found it with help from tgreaves, just in case some one comes looking for this info further on someday. If you remove the sealing ring on the wastegate then you will see a 13mm bolt, remove it.. Then you can turn the bolt under that and adjust the boost.. Raise it up to lower boost and down to raise boost..
hondastudent1on1
03-28-2007 10:14 AM
hondaguyexsi
08-10-2005 12:00 PM
ITSTOCK
04-14-2004 07:37 PM
