Received Moroso oil pan...pro and con of this part?
OK, the part that is circled in red. What is the purpose of having it in there while driving???? What is the purpose of not having it in???? This is my first time having this pan and i read some where saying you can take it out.
It's a baffle to keep oil around the oil pump pickup. It makes sure the pickup isn't starved under hard accelleration/decelleration, while going uphill/downhill, etc.
Who is Mr Robot?
Re: (redturbocivic)
on the topic of moroso oil pans... is that the new stamped steel one? whered you get it, im looking for the autox or whatever its called version
Re: (wantboost)
Yep, it is the new one they came out with. I got this off ebay from this company..... http://www.competitionwarehouseusa.com and the thing I like about it you use your stock pick up
Re: (redturbocivic)
This is the new race one that allows for the full 5 qts. of oil?
Does it come already tapped for a fuel return or no? Need one of these so I don't destroy my stock one on the streets around here.
Re: (D-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-t »</TD></TR><TR><TD CLASS="quote"> This is the new race one that allows for the full 5 qts. of oil?
Does it come already tapped for a fuel return or no? Need one of these so I don't destroy my stock one on the streets around here. </TD></TR></TABLE>
Yes, it comes with a oil return tap. ALso comes with a oil temp plug in the back
Front
Back
Front
Back
Re: (synik)
How can it use both oem oil pick-ups when the si and the gsr have pick-ups that are necked differently? When it states it will fit and work with both motors.
Modified by 11psiTurboSI at 12:06 AM 6/16/2005
Re: (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">Yep, it is the new one they came out with. I got this off ebay from this company..... http://www.competitionwarehouseusa.com and the thing I like about it you use your stock pick up</TD></TR></TABLE>
That my buddy Lenny....always gives good prices.
Check my sig.
Check my sig.
Re: (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si »</TD></TR><TR><TD CLASS="quote">
Check my sig. </TD></TR></TABLE>
They look nice! I just got one from Lenny right after reading this. Thanks guys.
Re: (D@nnY)
Is this Lenny guy on this forum? I want to order one of these and there is no phone number, and the part does not even show up on the website, nor do most oil related products... Let me know, excellent price and will order asap.
Re: (NewportSI)
is this the stock looking pan with the kickout at the rear? I noticed there are several different kinds ranging from 130-410 bucks. By stock looking I mean contoured metal, not the rectilinear sheet aluminum race style one...
does this oil pan have any clearance issue with the ground cause my car is lower, and is this set in stone, use 5.5 courts of oil or 4? if i use 4 ill just get the regular stock looking one for 100 less
Re: (yellowhonda88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowhonda88 »</TD></TR><TR><TD CLASS="quote">is this the stock looking pan with the kickout at the rear? I noticed there are several different kinds ranging from 130-410 bucks. By stock looking I mean contoured metal, not the rectilinear sheet aluminum race style one...</TD></TR></TABLE>
yes has the kickout in the rear and made of metal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosnatch »</TD></TR><TR><TD CLASS="quote">does this oil pan have any clearance issue with the ground cause my car is lower, and is this set in stone, use 5.5 courts of oil or 4? if i use 4 ill just get the regular stock looking one for 100 less</TD></TR></TABLE>
5.5 quarts
5.5 quarts
Re: (yellowhonda88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowhonda88 »</TD></TR><TR><TD CLASS="quote">Is this Lenny guy on this forum? I want to order one of these and there is no phone number, and the part does not even show up on the website, nor do most oil related products... Let me know, excellent price and will order asap.</TD></TR></TABLE>
He hardly comes on H-T so the best thing to do is just call at (305) 251-8228 and ask for him.
