Cleaning inside of intercooler
Old Jun 12, 2005 | 10:43 PM
Timmay's Avatar
Default Cleaning inside of intercooler
What are you guys using to clean the insides of intercoolers? Mine has had some oil go through it and id like ot get it cleaned out before i use it
any suggestions?
Old Jun 13, 2005 | 12:57 AM
crx12's Avatar
Default Re: Cleaning inside of intercooler (Timmay)
Never done it but couldn't you just clean it like you would a radiator? Just use some degreaser as the cleaning agent? The only problem I see is making sure it's dried out completely before using it.
Old Jun 13, 2005 | 02:55 AM
Finland's Avatar
gasoline works great...but it's flammable...so be careful...
Old Jun 13, 2005 | 11:16 AM
Timmay's Avatar
Default Re: (Boondock Saint)
yea i was thinking gas to
its not thick oil just a little residue but id like it clean before i use it
Old Jun 13, 2005 | 11:19 AM
splitime's Avatar
Default Re: (Timmay)
parts cleaner tub.... didn't clean it off all the way before we started TIG'ing it .....
Old Jun 13, 2005 | 11:23 AM
Optiks.'s Avatar
Default Re: (splitime)
ever tried to weld a gas tank?
Old Jun 13, 2005 | 11:30 AM
shortyz's Avatar
Default Re: (Optiks.)
yeah put a buncha gas in it, put your hands on both inlet/outlet and shake the sob for 20 min.
Old Jun 13, 2005 | 11:31 AM
Timmay's Avatar
Default Re: (shortyz)
i was just gonna cap 1 end off and let the gas sit in there for a little while then wash it out with water
Old Jun 13, 2005 | 11:59 PM
Timmay's Avatar
anyone else?
Old Jun 14, 2005 | 07:35 AM
crucian's Avatar
From what I learned through the years of growing up, gas and water dont mix. I wouldn't do that.
Old Jun 14, 2005 | 09:00 AM
onePOINTsix's Avatar
Default Re: (crucian)
i've used gas and rubbing alcohol, both work great but i dont think you'd want to use a water based cleaner because you'll probally have some water left over in there
Old Jun 14, 2005 | 10:05 AM
Timmay's Avatar
Default Re: (onePOINTsix)
i guess the gas would dry
i just dont want to mess anything up
Old Jun 15, 2005 | 12:52 AM
Timmay's Avatar
anyone else?
Old Jun 15, 2005 | 03:46 AM
stackz's Avatar
at the jetties fishin'
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onePOINTsix &raquo;</TD></TR><TR><TD CLASS="quote"> and rubbing alcohol, </TD></TR></TABLE>
99 cents at the drug store. pour the bottle in and shake the hell out of the intercooler and drain. then let it sit overnight. clean and no residue. done and done cheap.
now go do it and quit asking.
Old Jun 15, 2005 | 12:10 PM
Timmay's Avatar
Default Re: (stackz)
well would gas work better than rubbing alcohol?
Old Jun 15, 2005 | 02:41 PM
civicross's Avatar
I just clean them out in the tub, used some dish soap and let it soak for a bit then rinsed it out real good.
Old Jun 15, 2005 | 03:13 PM
Turbo Dan's Avatar
if you use water and wanna be safe, just go for a short cruise with the outlet charge pipe removed from the intercooler and let the turbo blow out the water.
Modified by Turbo Dan at 4:51 PM 6/15/2005
Old Jun 15, 2005 | 03:20 PM
RACEPAK's Avatar
Default Re: (Turbo Dan)
i used carb spray.....
Old Jun 15, 2005 | 03:25 PM
B18EG6's Avatar
Default Re: (RACEPAK)
I have a similiar question - my car was sitting for a while and som ebugs made nest in one of my charge pipes (on the rust inside )
what would be a good way to make sure none of the bug bodies were in the IC?
Old Jun 15, 2005 | 03:35 PM
cua0's Avatar
timmy: i use brake clean the **** in the green can seems to work best, its about $2.50cad at princess auto here. cheap cheap. works good for everything. and it evaporates really fast and leaves no residue.
Old Jun 15, 2005 | 10:48 PM
Timmay's Avatar
Default Re: (cua0)
nice thanks a ton guys
marcusgnf
Welding / Fabrication
Jul 28, 2007 04:24 PM
FortunateFool.
Jun 15, 2005 05:56 AM
turbo gli
Mar 15, 2005 09:03 PM
DIRep972
Sep 24, 2002 01:38 PM
