JRSC boost question
Old Jun 16, 2005 | 02:31 PM
CivicSouls's Avatar
Default JRSC boost question
Has anyone heard of puting a smaller crank pulley on to lower the boost range on a B16?
Old Jun 16, 2005 | 03:22 PM
The-LS's Avatar
Default Re: JRSC boost question (CivicSouls)
never heard of anyone doing it on purpose but it would work. If you have a UD pulley on, boost will be lower. But why?
Old Jun 16, 2005 | 03:34 PM
m R g S r's Avatar
Default Re: JRSC boost question (Black-LS)
it's too fast for him
Old Jun 16, 2005 | 03:42 PM
CivicSouls's Avatar
My supercharger is pulling 9psi on the stock pulley and I wanted to turn it down till i could afford hondata. it detonates so i'm nott driving it till i cure the detonation problem. it was suggested by one of the tech guys at Jackson.
Old Jun 17, 2005 | 09:31 AM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSouls &raquo;</TD></TR><TR><TD CLASS="quote">My supercharger is pulling 9psi on the stock pulley and I wanted to turn it down till i could afford hondata. it detonates so i'm nott driving it till i cure the detonation problem. it was suggested by one of the tech guys at Jackson.</TD></TR></TABLE>
a stock JRSC setup should not produce 9 psi without upgraded pulley(s). You may have improper cam adjustments or a restrictive exhuast system. But to further verify you question, my buddy accidenlt left a UD crank pulley on his car when he installed a JRSC and boost was lower than promised so a UD crank will drop boost. If you plan to get tuned in the near future, save yourself some work and just zip tie the SC bypass valve open and run NA.
93b16delsol
Nov 18, 2005 09:45 AM
sleeprcivic12
Dec 24, 2004 02:21 PM
DDD
Oct 7, 2003 08:44 PM
1234
Apr 7, 2003 09:45 AM
el_Presidente
Mar 24, 2002 02:12 PM
