need help on timing settings
Old Jun 14, 2005 | 05:38 PM
93NTEGLS's Avatar
Default need help on timing settings
i need help on what my timing should be set at when i boost my teg in a couple of weeks. i have them set at 5 degrees on both intake and exhaust side. thanks
heres my mods:
stock b18a block and head
aem cam gears
aem fuel rail, fpr, walbro 255lph
msd 6a box, msd external coil, magnecor 8.5mm wires
tubular manifold, 2.5 dp, garrett t3 .42/.48, 38mm wastegate, greddy type s bov
Old Jun 14, 2005 | 10:09 PM
turtle-eg's Avatar
Default Re: need help on timing settings (93NTEGLS)
Leave them a 0 degrees until you get tuning done.... Adjust them on the dyno. What kind of cams are you using? If you're using stock ls cams.. I doubt there's much you can do with them as far as cam gears.
Old Jun 15, 2005 | 03:22 AM
93NTEGLS's Avatar
im going to get some crower 403's. or if you know where i could get some ctr or itr cams that would be better.
preludewillie
Apr 9, 2013 10:23 PM
Redvti
Mar 9, 2009 04:44 AM
slodel
Jun 10, 2004 05:24 AM
VtecDA9
Jun 11, 2003 10:53 AM
GSG2
Dec 22, 2001 04:51 PM
