b20@8 psi ... approx HP gains>??
just wondering the gain i scould look forward to while im underboost i guessed 60 hp but that is kinda a wild *** guess, well tell me what u think
Re: b20@8 psi ... approx HP gains>?? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">good tunin big turbo, about 250whp easy</TD></TR></TABLE>
ding! ding!
you are correct! 10psi and a good tuner can get you 250whp w/o a problem. I could have probably made more top end power, but i wanted quite. Greddy SP exhaust owns me. But I made up with a 225tq! turbo size im running is a simple t3/to4b
sad if ur motor only make less then 200whp @ 8lbs.
ding! ding!
Re: b20@8 psi ... approx HP gains>?? (ek9vboi2)
nah havent got the set up on yet, but i hear i should expect some good numbers but considering i just wanna keep the oboost low b/c of the weak *** thin cylinderwalls i should expect around 200
Re: b20@8 psi ... approx HP gains>?? (R6E6I6D)
Boost won't kill those walls it going to be the heat and/or the cylinder pressures. Keep your horsepower down and don't retard you ignition TOO much and you may be OK. I'm always hearing about B20's cracking so GL .
Sinner
08-14-2003 04:03 PM
Therumblingteg
04-19-2003 12:20 AM
