Smoking under boost
Old Jun 12, 2005 | 09:08 PM
chirp3rd's Avatar
Default Smoking under boost
ok i thinks its the rings are done but im doing compression like everyday im getting 190's accross the board everytime but the car is burning oil and smoking when i hit boast there is also just a lil bit of blowby but its always had a little bit. The cars been running on a vafc and fmu setup for like 2 years now i recently threw in new cams springs and retainers a month ago and it ran perfectly fine any ideas on what i could be
help me out honda gurus
Old Jun 12, 2005 | 09:24 PM
urbansi's Avatar
Default Re: Smoking under boost (chirp3rd)
first off what color is the smoke, i am sure that you know that turbo cars in general blow a little smoke out the tail pipe on the top end or under boost. If the car is running fine and such it may just be normal. I would suggest getting, or hooking up a wide band to see what shape the fuel and a/r's are at, then worry about your cp. It may just be normal blow by or you could need a valve adjustment.
anyone else
Old Jun 12, 2005 | 10:04 PM
chirp3rd's Avatar
smoke is white and u can smell the burnt oil
Old Jun 12, 2005 | 10:20 PM
97hb's Avatar
Thick white is water, blue is oil and grey/white is running a little rich. How much oil you burning every week?
Old Jun 13, 2005 | 10:13 AM
chirp3rd's Avatar
Default Re: Smoking under boost (97hb)
bout a quart
Old Jun 13, 2005 | 11:03 AM
adseguy's Avatar
white usually means collant, but if you putting in a quart a week maybe it's your seals. Check your return line for kinks and are you running a restrictor on the feed line and what size is you feed line. Also what is your oil pressure if you know it. You may just have too much oil going to the turbo, but a quart a week is A LOT to put in.
Old Jun 13, 2005 | 11:57 AM
chirp3rd's Avatar
Default Re: Smoking under boost (adseguy)
oil feed line size is a -3 imma check the oil return today but can it be the rings eventhough my compression test comes out fine
Old Jun 13, 2005 | 12:34 PM
EK_GSR's Avatar
i doubt its the rings if the compression test comes out fine (menaing within ~ 5 psi of each other)....... i think.....
Old Jun 13, 2005 | 04:43 PM
11SECEG's Avatar
you should do a leak down test. take out your spark plug and try to look inside to see if it dry inside. having oil on top of your piston will yield to a good compression even if your rings are toast....
40ray
Apr 14, 2011 01:55 AM
jdmcreations777
May 30, 2007 11:41 AM
!hybrid
May 25, 2006 05:55 AM
PMTypeR
May 21, 2002 07:15 PM
Guitarzann
Dec 21, 2001 07:59 PM
