Hesitates when I begin boost
Old Jun 14, 2005 | 12:54 PM
turboman's Avatar
Default Hesitates when I begin boost
Finished my y8 manifold and gsr tb install yesterday. I didn't have the proper fuel pressure regulator so I didn't test drive it til today.
Idles fine and even works under boost if I acelerate slowly so the boost comes on at a slow pace. But if I hammer it it hesitates and stumbles.
I'm not throwing any codes from what I can see. I already had the GSR throttle body on for a week before doing the intake manifold and it worked fine.
So yeah I can't figure out what might be causeing this. The spark plug wire was poped out when I first tried but I put it back in. Still same problem. There may be a slight kink in the pcv vavle hose. I'm not sure but if there is could that cause this?
Oh well any ideas.
Thanks
Old Jun 14, 2005 | 01:14 PM
igo4bmx's Avatar
what are u using for fuel management?
Old Jun 14, 2005 | 01:34 PM
turboman's Avatar
Default Re: (igo4bmx)
hondata
I am stumped
Old Jun 14, 2005 | 01:54 PM
igo4bmx's Avatar
did u retune after those changs?
Old Jun 14, 2005 | 02:13 PM
turboman's Avatar
no but would changing a manifold really require me to retune the computer? I haven't put on my new exhaust yet so I don't want to go get it retuned yet.
Old Jun 14, 2005 | 02:18 PM
igo4bmx's Avatar
Default Re: (turboman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboman &raquo;</TD></TR><TR><TD CLASS="quote">no but would changing a manifold really require me to retune the computer? I haven't put on my new exhaust yet so I don't want to go get it retuned yet.</TD></TR></TABLE>
what manifold did you have before? a y7?
if so yes i would reccomend it
a new exhaust (mostly if diameter changes) requires a retune too
Old Jun 14, 2005 | 02:27 PM
dustin's Avatar
Default Re: Hesitates when I begin boost (turboman)
are you leaning out? do you have a wideband etc?
Old Jun 14, 2005 | 04:11 PM
SOHCmaster's Avatar
changing the tb will affect the tune for sure, going from a smaller to larger hole, more air, hell yeah.. Thats why it pauses before it kicks in, also check tps settings...
Old Jun 14, 2005 | 04:14 PM
turboman's Avatar
Default Re: Hesitates when I begin boost (dustin)
It doesn't seem like it is leaning out at all. I don't have a wide band only the cheapo air fuel gauge. It looks the same but I know it's not acurate.
The motor is a d16z6.
Why would I be able to go into the boost slowly though?
Old Jun 14, 2005 | 04:15 PM
dustin's Avatar
Hmm I'm not sure. Try checking your TPS voltages at idle and WOT.
Old Jun 14, 2005 | 04:25 PM
turboman's Avatar
Yeah they are good. Like I said I was running the throttle body for a week. The tps is correct. It would be nice to fix but if I can't figure it out it's not the end of the world. I just have to drive slow til it's dyno tuned.
But I checked and rechecked and I am sure everything is correct.
Old Jun 14, 2005 | 04:26 PM
dustin's Avatar
no vacuum leaks?
Old Jun 14, 2005 | 04:47 PM
turboman's Avatar
No vacum leaks. Would you beleive I forgot to block one off when I first started it.
I'm wondering if somehow I banged the map sensor around and broke it. I don't think so but who knows???
Old Jun 21, 2005 | 05:27 PM
turboman's Avatar
Didn't get to the car till today.
Seems I had to turn the vtec way up. It must have been getting just way to much air then what it was programed for.
Old Jun 21, 2005 | 05:36 PM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
i was just about to say that. my car did the same thing when i had my vtec set to 4300. i brung it up to 5000 and i don't feel that slight bump it used to do.
playahwitgame
Jul 9, 2006 09:25 PM
integra3586
Jan 26, 2006 07:26 PM
2000vsm
Mar 25, 2004 09:34 PM
b18tdelsol
May 31, 2002 12:21 PM
KekeK-18
May 22, 2002 05:10 PM
