b16 or ls/vtec
Old Jun 15, 2005 | 03:22 PM
tegturbo's Avatar
Default b16 or ls/vtec
which way should i go i have a b17 and the oil line broke and now the bearings are fucked i have a b18 here so i can do a ls/vtec or i car buy a b16 short block from a friend cheap.what would be the best way to go.i have a garrett t28-t3 turbo set at 10 psi. thanks
Old Jun 15, 2005 | 03:31 PM
GDM Z28's Avatar
Default Re: b16 or ls/vtec (1.7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.7turbo &raquo;</TD></TR><TR><TD CLASS="quote">which way should i go i have a b17 and the oil line broke and now the bearings are fucked i have a b18 here so i can do a ls/vtec or i car buy a b16 short block from a friend cheap.what would be the best way to go.i have a garrett t28-t3 turbo set at 10 psi. thanks</TD></TR></TABLE>
ls/vtec.....more displacement and a longer r/s ratio....youll make more torque....
Old Jun 15, 2005 | 04:01 PM
tegturbo's Avatar
Default Re: b16 or ls/vtec (civicflnum1)
so you think ls/vtec would be better what about reliability.
Old Jun 15, 2005 | 04:11 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.7turbo &raquo;</TD></TR><TR><TD CLASS="quote">so you think ls/vtec would be better what about reliability.</TD></TR></TABLE>
its a t28 on 10 psi...you wont be making gob's of power so as long as you get a proper tune and set up the kit right you wont have problems.
a ls/vtec will be just as reliable as ne other honda motor on boost if you do it right
Old Jun 15, 2005 | 04:33 PM
tegturbo's Avatar
anyone have some numbers whats the power difference going to be. alot more torque i know but how much more and horse power and drag racing which is better.
Old Jun 15, 2005 | 04:35 PM
Tchleung's Avatar
LS will always make more TQ then a B16 at the same given HP. I usually see a difference of 10-20wtq. sometiems mroe depending on turbo. I jstu dynoed my stock b16 and hit a 270whp/175wtq on mustang dyno.
Old Jun 15, 2005 | 04:43 PM
tegturbo's Avatar
Default Re: (Tchleung)
the turbo isnt very big its a garrett t28-t3 set at 10psi it worked good on my b17 dont know how much power it never got to the dyno because of my oil line i am leaning toward the ls/vtec but i should just give up i just built the b17 and was breaking it in so i could go to the dyno oh well some day maybe.
Old Jun 15, 2005 | 04:45 PM
GDM Z28's Avatar
Default Re: (1.7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.7turbo &raquo;</TD></TR><TR><TD CLASS="quote">the turbo isnt very big its a garrett t28-t3 set at 10psi it worked good on my b17 dont know how much power it never got to the dyno because of my oil line i am leaning toward the ls/vtec but i should just give up i just built the b17 and was breaking it in so i could go to the dyno oh well some day maybe.</TD></TR></TABLE>
its a small turbo so thats going to help with torque as well....with a b16 or lsvtec youll make about the same hp and youll make more torque with the ls/vtec
Old Jun 15, 2005 | 04:46 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">LS will always make more TQ then a B16 at the same given HP. I usually see a difference of 10-20wtq. sometiems mroe depending on turbo. I jstu dynoed my stock b16 and hit a 270whp/175wtq on mustang dyno.</TD></TR></TABLE>
270/175wtq
when i had a stock ls turbo and when i was making 270-280whp i made 242wtq.....when i made 304whp i made 270wtq.
go with a ls/vtec....torque is good.
Old Jun 15, 2005 | 04:47 PM
tegturbo's Avatar
Default Re: (civicflnum1)
thanks looks like ls/vtec is the way to go
honda_student
Aug 5, 2007 10:41 PM
89crx23
Mar 9, 2006 06:58 PM
awdriscol4
Jan 18, 2005 02:08 PM
GOLDBERG
31
Dec 21, 2004 06:41 PM
b16vtecsol
11
Nov 9, 2003 04:10 PM
