Rev .5mm oversized valves same size as stock valves?
I ordered a set of Rev oversized valves 0.5mm.I put the stock and rev valves bottoms together and they are the same size. The only difference I see is the revs valves seats are alot thinner and narrower.Are the valves suppose to be bigger cause thats what I have to have to fix a nicked valve seat? Or is it all base on the margin of the valve?
Re: Rev .5mm oversized valves same size as stock valves? (earl)
Thanks. Makes me mad.Ive been screwed over so much lately.First Ive been waiting a month for my arps from lightning motorsports and then I order a set of rev valves from someone else and they send me the wrong ones.I should start ordering from you Earl.Maybe I'll get what I order.
Re: Rev .5mm oversized valves same size as stock valves? (Cloner)
amen to that.. seems like everything i order from an import shop takes 3 weeks to get to me. 2 weeks for the damn ppl to get it outta there shop, then a week to my house. Then if its the correct part im good to go
Got my pistons from earl btw. There tucked into there new motor, just gotta get everything back together, sigh..
flycatcher
04-26-2009 10:03 PM
