will a jrsc for a y8 fit a a6 block with a z6 top end
like it ways, the jrsc is for a y8, i believe it will fit a z6 as well. but will it fit a a6 block?
Re: will a jrsc for a y8 fit a a6 block with a z6 top end (93formula)
Yeah it fits. I emailed ya.
You probably won't even have to mess with the lower alt bracket. And you *might* have to remove the spacer washers on the idler bracket. The brackets are the same for all D-series kits, you will just have to put the charger on for yourself and then see where you will need spacers. The only point of the idler spacers and lower alt bracket is to get the belt as perfectly lined up as possible so it won't jump off track.
BLUE EH3
13
08-20-2006 12:18 PM
TABIAS
12-01-2003 04:23 PM
