best head gasket for sohc zc? building for boost
whats the best head gasket for the zc swap..non v tec..?
ive been staring at my friends zc long block for a few days and asking myself.. why go through the trouble of another dohc swap?
im looking for no more than 240.. i understand the d16 is good for 230 max with all stock internals.. so..
ported and polished head multi angle valve job..
cam/ im trying to locate a good turbo cam..any ideas?
valve springs,retainers
block guard
arp head bolts
a decent 2 or 3mm head gasket.. the turbo kit im going to build part by part.. i found some nice tubular manifolds cheap..im looking at t25 turbo or should i use a 14b?
i figure this should hold 240.. or am i wrong?? the h/g should drop the c.r low enough for higher boost levels correct.. inlinepro's drops the b16a and gsrs pretty low..from around 10.2 to around 9.6:1
thanks guys..any ideas would be great..
block guard
arp head bolts
