People using gt28rs, gt2871r....t25 housing
What manifold and downpipe are you using on your B-series for these turbo's?
Old posts suggest running a HKS t25 manifold, which i can't find anymore, and getting a custom downpipe made.
Kinetic Motorsports offers a t25 manifold with an external wastegate provision on it...which i don't want.
Is it just easier to get the t3 drop in housing and forget about the t25 hassel?
t25 housing .86 a/r gt28rs $880 new
t3 drop in .82 a/r gt28rs $1149 new
Suggestions
Suggestions
Re: People using gt28rs, gt2871r....t25 housing (96BLkGSR)
Look for the Greddy manifold, they are t-25/t-28 flanged.
Could probibly get them for around $100, and atp turbo makes a v-band discharge and then just fab up a dp for it and you are good to go.
Re: People using gt28rs, gt2871r....t25 housing (urbansi)
I have a gt28/71r on my b20z in my ef. all lovefab, fits and works great. if you want a pic i can post it up for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96BLkGSR »</TD></TR><TR><TD CLASS="quote">
Suggestions </TD></TR></TABLE>
Those prices are skewed... Both the GT28RS T3 or T25 housing is exactly identical except for the turbine housing, and all GT28RS are $1100+
The price you've quoted @ $880 is the GT28R, which is a smaller and less capable turbo.
You should get a T3 drop-in and skip all the mess. I only went with the HKS manifold with custom downpipe because I was able to tuck everything under the OEM heatshield and run a full size Fluidyne with fans.
Re: People using gt28rs, gt2871r....t25 housing (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger »</TD></TR><TR><TD CLASS="quote">
You should get a T3 drop-in and skip all the mess. I only went with the HKS manifold with custom downpipe because I was able to tuck everything under the OEM heatshield and run a full size Fluidyne with fans.</TD></TR></TABLE>
I was looking at this http://cgi.ebay.com/ebaymotors...%3AIT
seems legit?
I think avoiding the mess of the t25 might be a good idea and just go with the t3 drop in...thanks for the advice
seems legit?
Re: People using gt28rs, gt2871r....t25 housing (EF'n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF’n »</TD></TR><TR><TD CLASS="quote">I have a gt28/71r on my b20z in my ef. all lovefab, fits and works great. if you want a pic i can post it up for you. </TD></TR></TABLE>
pics would be good!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kebroz »</TD></TR><TR><TD CLASS="quote">i've a neukin ramhorn T25 flanged, what is your B series?</TD></TR></TABLE>
like to see this too
my b series...b18c1, if that's what u meant
pics would be good!
my T25 manifold:
and the 3" DP with dual O2 bungs:
the GT2871R .64 WG:
i think that a GT2871R work fine ou a B18C1 but, take a .86 housing and external WG 38mm if you want more of 12psi.
i looking for sold my 2871 .64 for a 3071 .86 with external WG to pushing 18~20psi (on a sleeved B16A2)
GT2871R .86
GT3071R .86 is apprx equivalent GT2871R drop in T3 .63
Modified by kebroz at 1:05 AM 5/7/2006
the GT2871R .64 WG:
GT2871R .86
Moderator
Re: People using gt28rs, gt2871r....t25 housing (1epmugenlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1epmugenlude »</TD></TR><TR><TD CLASS="quote">Bringing this back from the dead, so will the GT2871r turbo bolt up to a greddy h22 manifold?
They use the same turbocharger, so it should work, though I would use a different turbo altogether for the H22 engine.
