what would this vacuum port BEST be used for?
the one next to the brake booster port, near the IACV(bottom right). boost controller, wastegate, or BOV? currently mine is plugged and not used since I bypassed my IACV or EVAP (cant remember what it was used for). I assume it would be best for boost controller, and could tap into that line for the WG as well. But from what Ive read, its better to use different vac sources for each device if possible.
Modified by clip the apex at 1:05 PM 5/5/2006
Re: what would this vacuum port BEST be used for? (clip the apex)
what kinna manifold is that? I would just say if you don't need it then plug it but if you do then just use it for whatever you need if for...
Re: what would this vacuum port BEST be used for? (RICE POLICE SIP)
its an ITR manifold.
I know I can use it for any thing that needs a vac source, Im asking if it would work better for one thing compared to another.
Silva Bullit DC4
01-17-2008 02:06 PM
RTW DC2R
05-19-2006 04:42 AM
