Is 15psi to much on stock block?
Re: Is 15psi to much on stock block? (moesrex)
Hp kills motors, not boost.
What motor?
around 300whp seems to be the "new" 250whp for b-series motors.
A good tune and proper setup makes the difference.
What motor?
Around 300whp give or take.
How healthy is the motor. leak down, compression???
How long has it been since the timing belt and water pump have been changed.
I would look into into getting headstuds, JMO.
Re: (Hcivic02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic02 »</TD></TR><TR><TD CLASS="quote">put on pistons and rods and you should be better off</TD></TR></TABLE>
do it right the first time
Re: (RACEPAK)
i made 363 on my stock h22.. it can be done with the right tune. like mentioned above horsepower affects motors not so much psi.
Re: (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">
do it right the first time </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic02 »</TD></TR><TR><TD CLASS="quote">put on pistons and rods and you should be better off</TD></TR></TABLE>
You do not need a built motor to make 300whp.
Did any of you guys see the highest hp on stock block thread, and not only that someone made like over 500whp on a stock b16
It all can be done with the right process.
Re: (cuin9sec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cuin9sec »</TD></TR><TR><TD CLASS="quote">395whp on stock b18c...t3/t67 H.O.</TD></TR></TABLE>
I know a civic that made 477 on a stock gsr with a 72mm turbo.
I run 20 psi on my stock ls with an sc34.
