2000 b16 turbo?
Old May 2, 2006 | 07:09 PM
b_serious's Avatar
Default 2000 b16 turbo?
i have a turbo kit with a 45/48 trim ( i think, its small) t3 but has a 10psi spring in a tial wastegate. im pretty sure it would be too much for the stock internals to handle correct? should i change it out to 5psi spring?
Old May 2, 2006 | 07:40 PM
boostedeghatch's Avatar
Default Re: 2000 b16 turbo? (b_serious)
turbo is small, should be fine.
Old May 2, 2006 | 07:41 PM
RVCA97's Avatar
for info
Old May 2, 2006 | 07:42 PM
s2kdre's Avatar
Default Re: 2000 b16 turbo? (RVCA97)
psi doesnt mean anything, stock bottom end can handle 300whp safely.
Old May 2, 2006 | 07:47 PM
beerbongskickass's Avatar
Default Re: 2000 b16 turbo? (jdmhonda)
That turbo will die out just when your B16 starts to make power. I would seriously consider going with a bigger turbo.
Old May 2, 2006 | 08:22 PM
Attaus's Avatar
45/48 trim? Wth man?? haha.. jp, it's a good idea to play it safe in the beginning.
like bbka said, the turbo will most likely die before the motor (assuming you have a good tune!) so get a 50+ trim.
lilrobie69
Apr 16, 2011 03:51 PM
flangemastermike
May 31, 2006 11:51 AM
91rexdx
May 15, 2006 06:53 PM
eg6turb0
Dec 2, 2004 12:30 PM
hoggy
Mar 13, 2004 06:25 AM
