chipped ECU problem
Old May 7, 2006 | 09:08 AM
huge230's Avatar
Default chipped ECU problem
I am having a problem with my chipped ECU and was wondering if someone could help. Its a P06 chipped to run my H22 turbo. I am using a Willem enhanced burner and 27sf512 chips and hex offset 8000 while buring. My burner say the chip is programmed correctly
When i put the chip in my ECU i geta solid CEL but the fuel pump primes. I didnt not try and start it like this and dont know if i should.
Here is a pic of my chipped ECU. Oh alsoa stock P06 plugged in and the CEL goes away as it should. Suggestions would be appreciated.
Old May 7, 2006 | 09:15 AM
coneheadsracing's Avatar
Default Re: chipped ECU problem (huge230)
What program are you using for tuning? You may have turned off, or not turned off something you should of, in the misc section, or whatever one its in. Had a solid CEL with my P28, but the car ran great.
Old May 7, 2006 | 09:24 AM
huge230's Avatar
Default Re: chipped ECU problem (coneheadsracing)
i am using uberdata and tried it with a stock GSR bin and the same thing happened. In the MISC section i have knock sensor, VTEC, VTEC collant check PA sensor, ELD all checked with the rest unchecked
Old May 7, 2006 | 09:25 AM
huge230's Avatar
I thought the fuel pump wouldnt prime is the chip was programmed bad or even the there was something wrong with the EU which Im pretty sure there isnt
Old May 7, 2006 | 03:40 PM
huge230's Avatar
i tried to start it with the colid CEL. It fired immediatly but reved at 4k and i shut it down for obvious reasons. Anybody know what the hell is wrong?
Old May 7, 2006 | 04:02 PM
High rev could be a lot of things, not necessarily the ecu. Are you sure thats the right chip, i know i use the at29c256 chip. A vacuum leak can cause a high idle too.
Old May 7, 2006 | 04:04 PM
huge230's Avatar
ill check but how does an engine rev at 4k with the throttle plate closed even witha small vacuum leak
Old May 7, 2006 | 04:56 PM
allmotorSOHC16's Avatar
did the things run ok before the new chip? your showing tell tale signs of a bad burned chip or improperly installed chip/modded pieces. the solid CEL leads me to this. this should seem obvious but are you positve that your chip is facing the right direction? they are directional. also if you undo your J1 jumper it should revert to the factory built in program telling you that ecu itself isn't the problem instead something in the modified pieces.
i had the exact same problem with my po6, turned out to be a solder point was a little bit sloppy and was shorted to another pin of my chip.
dont quote me on this but i think i remembered the chip needed must be a minimum of a 256k chip. not any smaller, but i dont recall if using a bigger chip gives issues, it appears you are using a 512k.
Old May 7, 2006 | 05:15 PM
huge230's Avatar
Default Re: chipped ECU problem (allmotorSOHC16)
just tried a P06 just to see if the idle was fixed ( I know i shouldnt run the stock P06 even for the half second) and the idle was the same 4k. What could this be?
Old May 7, 2006 | 06:38 PM
lucidvtec's Avatar
sounds like a bad vacumm leak
or maybe a bad TPS sensor
Old May 7, 2006 | 09:25 PM
rdtech's Avatar
Default Re: (lucidvtec)
just cut the jumper to see if the check engine light goes away. If it does, then the ecus is good and maybe the chipping parts have a bad connections or short somewhere. It may even be the octal tri state buffer (74hc373)
double check the work.
If the engine light still comes on even with the jumper cut, then it could be a bad ecu since you said it works fine with another ecu.
If you find out that your ecu is bad, you can also purchase on of mine. I test it all before shipment.
Old May 8, 2006 | 07:08 AM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huge230 &raquo;</TD></TR><TR><TD CLASS="quote">i am using uberdata and tried it with a stock GSR bin and the same thing happened. In the MISC section i have knock sensor, VTEC, VTEC collant check PA sensor, ELD all checked with the rest unchecked</TD></TR></TABLE>
Since when does a P06 support a knock sensor?
Uncheck that and see what happens.
Old May 8, 2006 | 07:26 AM
huge230's Avatar
Default Re: chipped ECU problem (93turbo16)
i am having trouble saving changes in uberdata. It will save the injector changes but it wont saved any checked boxes. Any ideas why?
Old May 8, 2006 | 08:27 AM
93turbo16's Avatar
what version are you using?
Old May 8, 2006 | 08:34 AM
huge230's Avatar
1.7
Old May 8, 2006 | 08:39 AM
i assume that have added vtec capability to your p06 right? just curious if bin is looking for vtec and isn't finding any and throwing into "safe" mode. just a thought.
also have you tried crome? i found it to be easier to use. however im not sure of the bugs compaired to uber.
Old May 8, 2006 | 08:43 AM
huge230's Avatar
yes ihave added vtec to my P06. I think my TPS is bad so im looking for a new one but I still dont know how to save changes in uberdata. MAybe I will have to try crome
Old May 8, 2006 | 08:45 AM
raene's Avatar
Are you modifying the bin in the same directory as Uberdata? If it's not saving options you're definitely going to get a CEL.
Old May 8, 2006 | 08:49 AM
huge230's Avatar
Default Re: chipped ECU problem (raene)
i modify the bin and i click exit and it asks if i want to save it and i save it to the desktop. If i try and do a save as them it comes up "failed to assemble lsm" or something like and and says it could cause ECU failure. So i dont really know. I tried a few different uberdata versions
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
Staypuff578
Feb 25, 2010 04:23 PM
siekhatch
Jun 5, 2006 01:58 PM
96MidoriHatch
Oct 19, 2004 08:30 AM
baphomet
Oct 31, 2003 02:57 PM
