Is It Safe To Run Turbo Pistons N/A To Break In???
Hey guys!
i just got my motor back today and i was woundering if it is safe or not to run my turbo motor N/A first (header) to break in everything with my arias turbo pistons or not.... then after a few hundred miles put on my turbo setup??? let me know what you guys think!!!!
1 Post
It wouldn't hurt anything at all but there is no reason why you can't just break it in with the turbo on. Turbo motors are built with larger tolerances becuase of the added abuse they will take and do not require factory break ins.
Re: Is It Safe To Run Turbo Pistons N/A To Break In??? (Jake92eg)
i thought boost helps to break the motor in.. i just took it easy for the first 1000 miles, gradually increasing the load and rpm.
Re: (Soccerking3000)
you dont need to break a motor in if it was built right in the first place....... I have seen and had motors strait from the shop built and on a dyno and lasted with no problems, its a common mis conseption that people have that you have to put x number of miles on before tunning or dyno or boosting
Re: (BoostedEG6)
the best way to break in a motor is to run it hard on the dyno. by "babying" the motor X number of miles your not letting the rings set. theres a good article on this if i can find it. i think its in all-motor
1 Post
This is usually the method people refer to when doing a hard break in. I know it's written for bikes but I have broken in quite a few cars this way and never had a problem as well as all my bikes.
http://www.mototuneusa.com/break_in_secrets.htm
Re: (Jay_Sensing)
dood just put the turbo kit back on it.....and break it in that way....your rings won't set and you need to drive the car on break in the way you would once its already broken in......just my .02
Re: (cuin9sec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cuin9sec »</TD></TR><TR><TD CLASS="quote">nOObs...lmao</TD></TR></TABLE>
so i guess you came out of the womb nowing everything *******...lmao
you will be fine running with your turbo during break in
Guest
Posts: n/a
Re: (pitbullracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pitbullracer »</TD></TR><TR><TD CLASS="quote">so i guess you came out of the womb nowing everything *******...lmao
you will be fine running with your turbo during break in </TD></TR></TABLE>
no..its just common sense.
Well i broke in my motor N/A for 1000 miles before boosting it... 2 years later its still running strong. Even CR tests after 2 years show even numbers and the motor its like if it was built yesterday.
stocker2shocker91
07-14-2010 03:54 PM
