Air filter NOISE?
Old May 5, 2006 | 05:02 AM
boostdummy's Avatar
Default Air filter NOISE?
I just recently had my intake for my turbo moved to the fender behind my front bumper
Anyway I am using 3" piping and a Cone filter.
I now have a weird sound that I am getting when I spool up the turbo to around 15 psi then let off, bov opens up and I also get another sound thats coming from the intake. It sounds very weird hard to explain it...Almost like compressor surge.
Now I don't think its compressor surge because I was not getting it when I just had the filter right on the turbo. And the only thing changed in the setup was air filter location and the piping from turbo-air filter.
I thought it might have been the filter just sucking in but the sound only comes when I let off the throttle/boost.
Any thoughts?
Old May 5, 2006 | 05:43 AM
Muckman's Avatar
Moderator in Chief
Default Re: Air filter NOISE? (boostdummy)
It could be compressor surge, just now its resonating in the tube so its more audible. The conditions you described are where surge can exist, part throttle and closed throttle body.
What kind of turbo and blow off valve? You may want to try adjusting your bov.
Old May 5, 2006 | 05:52 AM
Tactic$'s Avatar
Mine did the same thing (and still does, a little) when I put on a filter...
I agree with Muck on this one. When you added the "tube" you may have made the sound a bit more noticable.
Old May 5, 2006 | 05:58 AM
drintegra's Avatar
Default Re: (Tactic$)
how do you fix it?
Cmpressor surge. Bigger BOV maybe
Old May 5, 2006 | 06:24 AM
boostdummy's Avatar
Default Re: (drintegra)
I am using GT30 with Greddy type s BOV.
I will try adjusting the bov. I thought You would only hear compressor suge on the intercooler piping and not the Intake
Old May 5, 2006 | 07:28 AM
Muckman's Avatar
Moderator in Chief
Default Re: (boostdummy)
Which GT30 are you using? Does it have an anti-surge compressor cover?
Old May 5, 2006 | 09:39 AM
boostdummy's Avatar
Default Re: (Muckman)
I am using the GT3071R .63a/r without the anti-suge cover @ 15 psi
Old May 5, 2006 | 03:28 PM
boostdummy's Avatar
would adjusting the bov be suffice enough to take care of the surge? Or is this a GT30 problem?
or should I just switch back to the turbo on the filter. Because I was getting NO SOUNDS of surge with the filter on the turbo...
more thoughts...
Old May 5, 2006 | 06:08 PM
boostdummy's Avatar
Alright I tried adjusting BOV and it didn't help at all.
I tried removing the intake piping again and bam cant *hear* or I am not getting the surge anymore.
I did some searching on the net for compressor surge and GT3071R and came across this explanation with suge and the this turbo I am using
"Essentially what is happening during surge is the air going into the compressor doesn't have enough speed and momentum behind it.
Since we are not (with modern turbos) dealing with just radial staight blades on the compressor, we need air velocity over the blades to help generate more pressure difference.
If we lose that (air) speed, the pressure difference is so great that the air stalls altogether, and escapes out through the inlet.
Then it rushes back in and the cycle happens all over again, which is when you hearing fluttering and pulsing."
Opinions.....
Old May 5, 2006 | 06:24 PM
Muckman's Avatar
Moderator in Chief
Maybe you have a poor flowing air filter...
JDM-EJ1
15
Feb 10, 2004 02:30 PM
RedTegLS
Dec 18, 2003 07:35 AM
Kutsuju_SLeePER
Oct 15, 2003 03:40 AM
freeplay
Sep 28, 2003 01:05 AM
ijjz
Sep 22, 2002 09:49 PM
