car revs fast and hard to 7000rpm then it struggles the rest of the way
Old 05-03-2006, 11:49 AM
Turbo O's Avatar
Default car revs fast and hard to 7000rpm then it struggles the rest of the way
why would my car be doing this?? i have a LS/VTEC turbo and the way the setup is my car should be pulling harder and faster the more i rev it. but instead it carries to 7000rpm very fast but rite after 7100 rpm it doesnt like to rev up any more. i have revved the car to 8000rpm but only once and even then it struggled to do it. the motor is built so its safe up to 11000rpm but i have my redline set to 9000rpm for breaking it in. the motor now has 800 miles but still wont rev all the way up.
well heres my set up :
ls/vtec fully built
8.5:1 or 9:1 on compression
550 rc injectors
60 trim turbo
timing IS correct
valve adjustment IS correct (cant hear ANY valve tapping)
timing is retarded at the dizzy
i have the walbro fuel pump but its not installed yet. do you think this could be the answer. i need help, and appreciate any one willing to help. but please dont comment if you dont know what you are talking about.
Old 05-03-2006, 12:44 PM
Importordomestic's Avatar
Default Re: car revs fast and hard to 7000rpm then it struggles the rest of the way (LS Boostin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS Boostin &raquo;</TD></TR><TR><TD CLASS="quote">why would my car be doing this?? i have a LS/VTEC turbo and the way the setup is my car should be pulling harder and faster the more i rev it. but instead it carries to 7000rpm very fast but rite after 7100 rpm it doesnt like to rev up any more. i have revved the car to 8000rpm but only once and even then it struggled to do it. the motor is built so its safe up to 11000rpm but i have my redline set to 9000rpm for breaking it in. the motor now has 800 miles but still wont rev all the way up.
ls/vtec fully built
550 rc injectors
60 trim turbo
timing IS correct
i have the walbro fuel pump but its not installed yet. do you think this could be the answer. i need help, and appreciate any one willing to help. but please dont comment if you dont know what you are talking about. </TD></TR></TABLE>
Problem is right there
Old 05-03-2006, 12:59 PM
99lspwr's Avatar
ls/vtec fully built
550 rc injectors
60 trim turbo
timing IS correct
Your gonna get sooo bashed dude...
Old 05-03-2006, 01:32 PM
ccivic's Avatar
Default Re: car revs fast and hard to 7000rpm then it struggles the rest of the way (99lspwr)
Why the hell is your timing retarded at the dizzy?
Old 05-03-2006, 01:46 PM
non-VTEC's Avatar
i have the walbro fuel pump but its not installed yet. do you think this could be the answer. </TD></TR></TABLE>
put the fuel pump in. set the ignition timing correctly at the distributor and tow the car to a good tuner because you obviously have no idea what you are doing.
Old 05-03-2006, 07:41 PM
Turbo O's Avatar
Default Re: car revs fast and hard to 7000rpm then it struggles the rest of the way (Importordomestic)
man im sorry i dont know here i wrote that. must of been high. i REALLY meant to write that the dizzy is nuetral and so are the cam gears. my bad but i really need help on with problem. i meant i figure its the fuel pump but what else would cause this problem??
Old 05-03-2006, 08:06 PM
Zakar's Avatar
it is the fuel pump.. and if you dont put it in you will blow up your engine... if you dont take it somewhere to be tuned you will blow up your engine.. if you dont put oil in it you will blow up your engine..
busta7777
01-01-2012 01:41 PM
teamitr
09-01-2007 07:41 AM
claytonsmith
06-03-2006 09:09 PM
Evil DOHC
03-26-2004 09:42 AM
dwilson
01-24-2003 04:07 PM
Quick Reply: car revs fast and hard to 7000rpm then it struggles the rest of the way
