is this a sc61?
Old May 5, 2006 | 09:19 PM
komat's Avatar
Default is this a sc61?
i just got this turbo from a ht user. i just wanted to make sure this is a sc61. I saw other pictures of the exhaust side. all of them had precision cast on them while my say garrett.
Old May 5, 2006 | 10:17 PM
SpeedingHatch's Avatar
Default Re: is this a sc61? (komat)
I dont think so. sc61's are made by Precision
Old May 5, 2006 | 10:22 PM
dpetro1's Avatar
Default Re: is this a sc61? (SpeedingHatch)
also that one pic looks like it has a 4-bolt exhaust housing, i thought all the precisions used the 5-bolt.
Old May 5, 2006 | 10:24 PM
Jockobo's Avatar
Default Re: is this a sc61? (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">also that one pic looks like it has a 4-bolt exhaust housing, i thought all the precisions used the 5-bolt. </TD></TR></TABLE>
you can get the 4 bolt housing but since precision doesnt make it they use garrett's
Old May 5, 2006 | 10:28 PM
komat's Avatar
Default Re: is this a sc61? (Jockobo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jockobo &raquo;</TD></TR><TR><TD CLASS="quote">
you can get the 4 bolt housing but since precision doesnt make it they use garrett's </TD></TR></TABLE>
alrite
i was wondering why the casting was garrett instead of precision
Old May 5, 2006 | 10:39 PM
SavEM1's Avatar
its a better trim?
Old May 5, 2006 | 11:44 PM
g2lsvtec's Avatar
Default Re: (Hcivic02)
look on the back of the compressor houseing outlett, it should have some #s scratched into it like sc61e... u kno, and tell us what it says, that basicly can tell u if it is or not, deff looks like a presicion turbo...
Old May 6, 2006 | 12:17 AM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedingHatch &raquo;</TD></TR><TR><TD CLASS="quote">I dont think so. sc61's are made by Precision</TD></TR></TABLE>
Old May 6, 2006 | 12:36 AM
Jockobo's Avatar
Default Re: (g2lsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2lsvtec &raquo;</TD></TR><TR><TD CLASS="quote">look on the back of the compressor houseing outlett, it should have some #s scratched into it like sc61e... u kno, and tell us what it says, that basicly can tell u if it is or not, deff looks like a presicion turbo... </TD></TR></TABLE>
is that it in the first picture? 61E
Old May 6, 2006 | 02:17 AM
SuperSi's Avatar
I dont think so SC61's are made by Precision
Old May 6, 2006 | 05:38 AM
Soccerking3000's Avatar
Default Re: is this a sc61? (SuperLade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperLade &raquo;</TD></TR><TR><TD CLASS="quote">I dont think so SC61's are made by Precision</TD></TR></TABLE>
you can get teh 4 bolt hot side from garrett, try reading the thread
Old May 6, 2006 | 06:01 AM
drintegra's Avatar
Default Re: is this a sc61? (Soccerking3000)
I was told by pheonixturbo.com that the SC61 is their"blowzilla" turbo and that the precision sc61 is all garett but the casting has their name on it. Just what I was told. Good luck
Old May 6, 2006 | 06:11 AM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Default Re: is this a sc61? (drintegra)
I have an sc61 sc-6152e 4 bolt and it says precision on the turbine housing.
Old May 6, 2006 | 06:18 AM
B18C1CYA's Avatar
see there are some #'s engraved in where the outlet is on the compressor , what do they say ??? and my SC61 has the same 4 bolt housing because precision did not start casting there own 4 bolts at the time that one was built, also a SC61 has a gt35 exhaust wheel and a 61mm intake side , good combo
Old May 6, 2006 | 06:42 AM
alpha's Avatar
Look at the compressor outlet.
Old May 6, 2006 | 07:34 AM
ineedhelp's Avatar
Default Re: is this a sc61? (0x64)
he bought this turbo from me. look at the outlet of the compressor side. its hase the numbers engraved on there.
Old May 6, 2006 | 07:58 AM
yee SERIOUS's Avatar
when i first looked, i said no. but i do see the part of the 6152e writing.
Old May 6, 2006 | 08:12 AM
komat's Avatar
Default Re: (undercoverdc2)
the sc6152 is on the outlet
wasnt sure if it was the owner that engraved it on it
or if it was precision
thanks for the answers!
Old May 6, 2006 | 01:30 PM
s2kdre's Avatar
Default Re: (komat)
most precision turbos use a garrett hot side.
Old May 6, 2006 | 10:27 PM
EnzoSpeed's Avatar
Default Re: (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">most precision turbos use a garrett hot side.</TD></TR></TABLE>
That's why I gave a when someone said SC61's were made by Precision and not Garrett. I guess I thought it was common knowledge that Precision turbos are just souped up Garrett turbos.
Old May 6, 2006 | 11:12 PM
93LSivic's Avatar
Default Re: (EnzoSpeed)
All Pecision turbo's ARE Garrett turbo's. Precision just has their own turbine housing castings.....which are'nt any different that the garrett housings. I had the T351 (garrett 4 bolt outlet) housing SC61 and it looked exactly like that. If you really want to know if its an SC61 you will need to measure the wheels....housings dont really matter.
Old May 6, 2006 | 11:15 PM
alpha's Avatar
Default Re: (93LSivic)
And Precision for the most part uses their 5-bolt housing.
GFurm
Welding / Fabrication
43
Jun 6, 2007 08:51 AM
Honda Sport
Mar 9, 2007 09:41 AM
tsxdriver
Acura TSX
33
Oct 11, 2006 01:34 PM
slow_redcivic
Apr 16, 2006 11:11 PM
IT'S ME DAVID
Aug 30, 2005 11:34 PM
