Turbo LS uberdata issues
Old May 3, 2006 | 08:34 AM
quick_ls's Avatar
Default Turbo LS uberdata issues
Well i am having a few issues with trying to get uberdata to lean out and run richer at different spots on the map.
Right now 0-10 psi is getting 11.2-11.9 afr
But at idle its runner 18 - 21+ afr
and when just cruising around its getting 10-12 AFR
So, we leaned out some of the vacuum map and i got it to run around 14.5-15.1 crusing around in vacuum. BUT my problem is when i shift, it spikes LEAN.
how do you go about correcting this problem?
running 450cc injectors, uberdata 1.66, 42psi on the fpr.
would tps enrich help my problem?
Old May 3, 2006 | 08:48 AM
adseguy's Avatar
Default Re: Turbo LS uberdata issues (quick_ls)
When you decelerate or let off the gas no more fuel is being dumped in the engine. The wideband will pick up this non-exisitant fuel and display lean. EVERY wideband does this when you shift or decelerate. It's normal
bigtom388
Feb 24, 2012 05:47 AM
ef9itb
Engine Management and Tuning
Jun 30, 2010 12:27 PM
pro1342
13
Sep 13, 2005 12:01 PM
mrx
Apr 26, 2005 09:17 PM
cliff666
Jul 10, 2004 11:54 AM
