quick wastegate question
Old May 3, 2006 | 12:55 PM
huge230's Avatar
Default quick wastegate question
what would happen if a wastegate was run with no line running to the compressor or anywhere for that matter?
Old May 3, 2006 | 01:17 PM
nfn15037's Avatar
Default Re: quick wastegate question (huge230)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huge230 &raquo;</TD></TR><TR><TD CLASS="quote">what would happen if a wastegate was run with no line running to the compressor or anywhere for that matter?</TD></TR></TABLE>
It would never open.
Old May 3, 2006 | 01:57 PM
huge230's Avatar
is it ok to plug the existing hole and drill and tap another ina different location? Mine faces the block and cant out anything on it. thanks
GS-R Civic's Avatar
You would boost to 500psi, buts its ok cuz I hear that stock hondas can hold 600psi
Old May 3, 2006 | 01:58 PM
GS-R Civic's Avatar
Thats fine, just take it apart and make the metal shavings don't end up where they are not suppose to be
Old May 3, 2006 | 02:45 PM
teg racer 877's Avatar
Default Re: quick wastegate question (GS-R Civic)
so even if its like a 5 psi spring it would not open without vac.?
Old May 3, 2006 | 02:58 PM
GS-R Civic's Avatar
Default Re: quick wastegate question (teg racer 877)
I am not sure at the exact point at which it would open, but it would be very high. If the car is not tuned, or has boost cut its gonna feel reallly fast then BOOM.
I had a defective filling on my wastegate and it kept blowing off everytime I hit boost. 7psi spring and I hit ~14psi before I noticed by looking at my guage. This is something that you definatly don't want to mess around with.
Get it done the right way .
H22TurboNos
May 13, 2007 01:06 PM
huge230
May 3, 2007 10:53 PM
mrx
Dec 26, 2005 10:43 AM
ham
Nov 19, 2005 02:57 PM
hybridb18
Dec 2, 2002 09:29 PM
