Low compression k20a3 question.
Old May 2, 2006 | 11:52 PM
KOREAN's Avatar
Default Low compression k20a3 question.
I'm not very fond of forced induction since I'm a NA fan, but it's a bit tempting...
I've been reading that the lower compression of the k20a3 is somewhat beneficial for boosting, as compared to the k20a2's slightly higher compression.
My question is: When is the lower compression actually beneficial?
For instance, would a small turbo at low boost produce more power in a k20a2 or an a3? How about a small turbo at high boost levels?
Or would extensive and proper tuning even it out?
Old May 3, 2006 | 01:13 PM
KOREAN's Avatar
Default Re: Low compression k20a3 question. (korean)
bump?
Old May 3, 2006 | 01:18 PM
beerbongskickass's Avatar
Low compression is good with boost because you can make more power safely on pump gas. Since most of us have daily drivers on pump gas this is a good thing.
Old May 3, 2006 | 09:00 PM
StylishDOHC's Avatar
Default Re: Low compression k20a3 question. (beerbongskickass)
If you already got the a3, boost it..it seems like they have a plastic intake manifold? might need to change that....if you have or are getting the a2 just make sure you have a good tuner.You'll need it with 11:1 compression.
Earthworm Jim
Jan 2, 2008 04:11 PM
slowcrx954
Nov 23, 2006 07:49 AM
TehMoonRulz
May 16, 2005 01:15 PM
turbo89civicb18hatch
Nov 23, 2004 01:08 PM
B18C Hatch
Sep 17, 2003 05:41 PM
