When assembling a turbo do you....(Help)
Old May 5, 2006 | 06:01 PM
B6tPoweredMx3's Avatar
Default When assembling a turbo do you....(Help)
Use any kind of sealant or gasket on the intake side of the turbo that mounts to the backing plate?
My mazda will not build more than 2 lbs of boost, on a freshly rebuilt turbo. At first i thought it was the Intercooler piping.I found some leaks and fixed them and then pressure tested it to 15 lbs, held fine.
Car will idle and drive beautifuly out of boost, it just will not build boost.
Checked to see if the internal wastegate was stuck open, it wasnt, it was sealed nice and tight. Of course i did this with the car off, some jackass at my local parts store suggested i remove the DP and start the car to see if for some reason it opens when the car was idleing.....
Any ideas? Help?
Old May 5, 2006 | 06:05 PM
coneheadsracing's Avatar
Default Re: When assembling a turbo do you....(Help) (B6tPoweredMx3)
shouldn't have to remove the downpipe, just watch your actuator after you start your car. It is possible that your wastegate is messing up. I have a gasket on mine, if you left it out, i'd think you'd still make plenty of boost though. so i dunno.
Old May 5, 2006 | 06:20 PM
Default Re: When assembling a turbo do you....(Help) (coneheadsracing)
I know its building boost ( i can hear the turbo) but its leaking somewhere and i cant ******* find out where.
Now if it was a leak in the intake manifold, On a MAF sensored car it would idle like **** right?
Old May 6, 2006 | 10:04 AM
TTT.
Would it be a good idea to remove the downpipe again and then pressureize the wastegate with a foot pump to see if it opens early?
Old May 6, 2006 | 10:39 AM
onefstek's Avatar
the compressor should have a big "O" ring to seal against. At least my garrett turbo does.
Old May 6, 2006 | 10:52 AM
Default Re: (onefstek)
Ok cool looks like im taking it apart,and have to find a giant friggin oring.
Homedepot maybe?
Old May 6, 2006 | 10:56 AM
Default Re: (B6tPoweredMx3)
i made a gasket out of the do it yourself gasket you can get from local parts store, napa for sure. Its big, so its easy to cut out with scissors.
Old May 6, 2006 | 11:06 AM
Default Re: (coneheadsracing)
Will let you guys know later if this solves it, keep the ideas comming though
Old May 6, 2006 | 04:49 PM
After consulting with a few other people they suggested tying the wastegate closed which in the end I did. STILL will not build boost. Im going to end up taking off the upper intake plenum to see if maybe its leaking somewhere in there.
Old May 7, 2006 | 05:21 AM
You have clamps on all of your couplings right? Hows your blow off vavle, is it stuck open?
Old May 7, 2006 | 05:26 AM
Yes i have clamps on all of the couplers, that was the first thing i checked, also checked the bov by removing it. Still nothing, im convinced that it is a leak somewhere in the intake manifold, im going to re route my boost gauge so that it reads off the port on the turbo, so i can see if the turbo is creating boost, if not ill add that seal i was talking about earlier.
Old May 7, 2006 | 07:40 AM
good news: found the leak, 10 psi felt good, for the 1 pull.
BAd news:turbo now eats oil. (expletive)
Old May 7, 2006 | 01:24 PM
onefstek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B6tPoweredMx3 &raquo;</TD></TR><TR><TD CLASS="quote">good news: found the leak, 10 psi felt good, for the 1 pull.
so where was the leak???
Old May 7, 2006 | 01:27 PM
At the compressor seal, there is a gasket needed.
Its alright its all under warranty
MiMiK
Dec 10, 2005 06:21 PM
93turbo16
Sep 14, 2005 11:15 AM
RFd15bhatch
Jun 1, 2005 03:35 PM
eg6T
Aug 27, 2004 12:39 PM
MooreBoost
Aug 8, 2004 11:14 AM
