compression test right?
Old May 3, 2006 | 06:40 PM
Civic92Turbo's Avatar
Default compression test right?
130 all a cross seem weird...
SRP 9.2
.20 over
PNP head
OEM Head gasket
Turbo 2 cams crower
Manley Valve Tran
Titm retainers
Polish cranks
ARP and AEBS Main and Head Studs
Crower H-Beams
5 exhaust and 3 intake
adictionbass's Avatar
Default Re: compression test right? (Civic92Turbo)
WOT? thats low
Old May 3, 2006 | 07:15 PM
StolenTeg's Avatar
Default Re: compression test right? (adictionbass)
Your compression should be 190-210, mine is 9.5 and i get 210 across the board
Make sure the car is fully warmt up and gas to the floor while cranking
Old May 3, 2006 | 07:17 PM
nonvtecD's Avatar
Default Re: compression test right? (StolenTeg)
Yeah too low. If it doesn't smoke though just turn up the boost to make up for it
Old May 4, 2006 | 07:54 AM
i did this Comp when the car was warm and i took the fuse out...
Old May 4, 2006 | 09:07 AM
yee SERIOUS's Avatar
what do u mean fuse out? i have 235 straight across for stock motor. you should be at least 190's.
Old May 4, 2006 | 09:09 AM
StolenTeg's Avatar
Default Re: (undercoverdc2)
He probably meant the fuse for the fuel pump
Old May 4, 2006 | 09:10 AM
bdavis's Avatar
Default Re: (StolenTeg)
did you hold the gas pedal to the floor while doing this?? have you tried another tester??
Old May 4, 2006 | 03:20 PM
ill try a leak down test soon...
Old May 4, 2006 | 03:34 PM
urbansi's Avatar
Default Re: (Civic92Turbo)
Ha this is a funny post, i just went through something like this, it turns out the valve in the tube on my compression tester was messed up. I went out and bought a new tester and gauge from autozone and my readings went up from 140ish-psi across the board to 200psi.
Old May 4, 2006 | 08:44 PM
hmm...dam..
Old May 4, 2006 | 10:56 PM
lucidvtec's Avatar
i have about 150 across the board....and it smokes on decell....only a little bit....it's weird....fully built...sleeved motor.....
any guess's........the motor will be pulled soon....i'm a little ticked..being it's only seen 17psi max ever....on a fully built motor
i'm thinkin its a head problem
Old May 4, 2006 | 11:33 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic92Turbo &raquo;</TD></TR><TR><TD CLASS="quote">i did this Comp when the car was warm and i took the fuse out...</TD></TR></TABLE>
the gas pedal needs to be to the floor when you do the test otherwise your not gonna get any air in the cylinders.
Old May 5, 2006 | 06:56 AM
urbansi's Avatar
Default Re: (lucidvtec)
Do a leak down. They are way more accurate than compression tests.
MikeD21
Engine Machining & Assembly
14
Jan 3, 2019 10:54 AM
99em1civicsi
40
May 28, 2016 09:49 AM
JDM EJ1 95
Sep 8, 2004 09:15 AM
MLogan
May 22, 2003 01:09 PM
eg crunkmonster
Mar 31, 2003 08:29 AM
