NOOB b18b nitrous question nitrous gurus plz chime in
I wanna run a 80-100 shot direct port...but everybody's telling me i have to retard my timing...but i dont wanna lose and power when iam off the bottle...can i just run race gas with out retarding my timing? also will stock injectors be ok? i basically got everything heres my set up
b18b block
10.5:1 je pistons
eagle rods
b&m fuel pressure reg
Walboro 255 in tank fuel pump
the head is completly stock
NX direct port kit
Is there ne thing else i need to complete this project
Also the car wont be driven everyday so idf race gas is the way to go so be it
thanks
-D
b18b block
10.5:1 je pistons
eagle rods
NX direct port kit
thanks
-D
Re: NOOB b18b nitrous question nitrous gurus plz chime in (quikcivic)
well if you are running direct port your injectors arent going to be adding any more fuel than they usually would. As for timing i would remove some and get it tuned, because as soon as the nitrous goes your fuel pressure will drop, you need an alternate fuel map just for nitrous along with a timing map.
BTR ALL MOTOR
07-31-2003 01:41 PM
bw54867
09-29-2002 03:33 AM
