what oil pump should i use
im going ls turbo and i was wondering if i should use the stock ls or maybe a vtec one like gsr. im doing a complete rebuild so all new parts
Re: what oil pump should i use (3a_eg_hatch)
if you have a 96+ b18b1 then the pumps are all the same between b-series (so ive heard). if not and you want to change the oil pump then upgrade it to a 96+. a little more oil pressure wont hurt. your stock pump will work fine too even if your motor isnt a 96+.
