sleeve size
Old May 6, 2006 | 10:20 PM
red beast's Avatar
Default sleeve size
hi, i just had my b18b block sleeved with darton 81mm sleeve.
i also purchase a set of srp 8:5.1 pistons they are .0010 over.
the question is can the piston fit the block.
Old May 6, 2006 | 11:07 PM
93LSivic's Avatar
Default Re: sleeve size (red beast)
No. You will have to take it to a local machine shop and have it bored and honed to your pistons. Since your running the SRP's you will more than likely have a low piston to wall clearance due to material they are made of. Hope this helps and good luck with your project
Old May 6, 2006 | 11:12 PM
dunkd's Avatar
you need 81.25mm bore.
Old May 6, 2006 | 11:51 PM
93LSivic's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">you need 81.25mm bore.</TD></TR></TABLE>
But do the SRP pistons he has have the p/w spec built in to them or not? I dunno, I wouldn't use those pistons personally but he's gonna have to look into that I suppose. Give their tech line a call, you will definetly want an accurate answer to your question or you will have serious problems later on down the road.
Old May 7, 2006 | 03:59 PM
red beast's Avatar
Default Re: (93LSivic)
thanks for the help what piston would you recommend.
i might sell the srp and get the 81mm to match the sleeves
Old May 7, 2006 | 04:51 PM
morgan@synapse motorsport's Avatar
cp all the way
Old May 7, 2006 | 05:35 PM
Mugencrxsir1's Avatar
Default Re: (hybrdthry911)
If you were'nt planning on boring out your sleeves, then just send the pistons back for stock 81mm pistons Also, I'm assuming the sleeves are honed, and ready to go?
Old May 7, 2006 | 06:41 PM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrdthry911 &raquo;</TD></TR><TR><TD CLASS="quote">cp all the way</TD></TR></TABLE>
What did that have to do with this thread?
Old May 7, 2006 | 06:58 PM
"thanks for the help what piston would you recommend"
read the reply above mine
he asked what pistons he should use
Old May 7, 2006 | 09:21 PM
Muckman's Avatar
Moderator in Chief
Your right. Hes better off sticking with what he has already because the cylinders will likely need a bore & hone anyways.
Old May 8, 2006 | 04:00 PM
red beast's Avatar
Default Re: (Muckman)
so you guys telling me i can keep the srp
Old May 8, 2006 | 06:18 PM
Default Re: (red beast)
I would stick with the srp brand, but you need the 81mm pistons if the sleeves are already honed/preped.
Old May 8, 2006 | 06:33 PM
red beast's Avatar
Default Re: (Mugencrxsir1)
nothing have been done to the sleeves yet i just got them.
the inside walls feel a bit rough
if my questions seems stupid i am new to the turbo seen
Old May 9, 2006 | 01:43 AM
the walls shouldnt feel rough. u will need to hone or bore it.
Old May 9, 2006 | 01:56 AM
SnOOpY-NO's Avatar
Keep the pistons and bore the sleeves to get the correct clearance, or get new pistons for 81mm so you get the correct clearance without boring..
81mm pistons have the correct clearance build inn to be used in an exactly 81mm sleeve..
Old May 9, 2006 | 06:43 AM
cuin9sec
Guest
Posts: n/a
Default Re: (dunkd)
Old May 16, 2006 | 10:34 AM
Golden Eagle's Avatar
Default Re: (SnOOpY-NO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnOOpY-NO &raquo;</TD></TR><TR><TD CLASS="quote">Keep the pistons and bore the sleeves to get the correct clearance, or get new pistons for 81mm so you get the correct clearance without boring..
81mm pistons have the correct clearance build inn to be used in an exactly 81mm sleeve.. </TD></TR></TABLE>
he said the Walls fill ruff so 81mm piston is not going to help him it will need to be bored and honed
MatHadder
Oct 1, 2006 05:59 PM
evade this honda
Jul 28, 2006 07:20 PM
ekVtecPower
Jun 27, 2006 11:18 AM
crx1856
Nov 3, 2003 05:10 AM
roydogg
Aug 6, 2003 06:49 AM
