EMS Solution for D16V Engine?
Old May 5, 2006 | 06:39 AM
mrx's Avatar
mrx
Default EMS Solution for D16V Engine?
Hallo,
is there anybody who knows if there is a EMS solution for the D16V engine? ECU code is unfortunatly unknown at the moment.
The car is a 2000 Civic Hatchback (Gen. 7) with 110kw.
I'am not sure if y OBD1 swap is possible on this car because of the different VTEC the car has against the obd1 B-Series engines.
but maybe i'am wrong and a swap is possible without problems... is there anyone who has done a turbo setup on such a car?
Thanks
Old May 5, 2006 | 08:04 AM
HiProfile's Avatar
Default Re: EMS Solution for D16V Engine? (mrx)
I always considered the 99-00 to be the same gen as 96-98, 6th gen. 01-05 is gen7, and a different ecu code completely.
If it is a 2001-2005 d16v sohc vtec motor, my limited knowledge with that motor is just the AEM EMS. I don't think obd1 swap is at all possible.
Old May 5, 2006 | 10:21 AM
mrx's Avatar
mrx
Default Re: EMS Solution for D16V Engine? (HiProfile)
Yes, you are right, its a 2001 model...
does anyone know where's the problem with the obd1 swap? some special vtec actuators that are not present in obd1?
thanks
curiousgeorge1
Jul 11, 2010 10:51 PM
heeltoehonda
Engine Management and Tuning
Nov 19, 2009 11:41 AM
dizzyek
Jan 24, 2006 04:29 PM
gearhead313
Mar 2, 2003 01:44 PM
