datalogging with plx wideband, is this how you hook it up?
ok, im using freelog, i dont know if any of you have used it. anyways, its all working except for the 02 reading. so this is how i hooked up the wideband. all i did was locate pin d14 because im obd1, take the wideband signal coming off the guage which is a white wire (accoring to the plx instructions) and i spliced it into that pin d14 connection. o2 sensor is disabled in the rom. now my qustion is do i "splice" into the pin d14 or do i "cut" the wire completely becuse the 02 is already disabled and then do i just connect it to the wideband output (white wire) to the ecu input i just cut? thanks
93ludeSi
11-15-2003 08:02 PM
wickedxboi
03-22-2003 01:51 PM
