Problem boositng with Spoolin log mani
Old Jan 12, 2008 | 08:16 PM
Speed94's Avatar
Default Problem boositng with Spoolin log mani
For some reason my tuner says he cant get the boost to go over 12 PSI. every time it gets right around there it drops. He says its something about the back pressure or something. Car made 320 which was less then when I had my previous cast mani on there. I know there are a lot of people make a lot more power with the same setup. Heres mine:
Precision SC34
Spoolin log mani
spoolin 3" downpipe
full 3" Apexi N1
LS/VTEC (GSR head)
ARP head studs
Edelbrock Intake Manifold
Precision 880's
Walboro fuel pump
Greddy Type RS BOV
Tial 38mm gate
Block guard
GM 3 bar map sensor
Hondata s300
Any help would be appreciated.
Old Jan 13, 2008 | 04:57 AM
kyden's Avatar
Default Re: Problem boositng with Spoolin log mani (Speed94)
what are you running for boost control?
Old Jan 13, 2008 | 05:30 AM
Speed94's Avatar
Default Re: Problem boositng with Spoolin log mani (kyden)
I run a perrin EBCS unit thats hooked into the hondata.
Old Jan 13, 2008 | 07:32 AM
xenocron's Avatar
Have you leak tested your charge piping?
Is he saying that the back pressure is too high for the turbo to overcome and not boost any higher than 12 psi?
Old Jan 13, 2008 | 01:17 PM
Speed94's Avatar
Default Re: Problem boositng with Spoolin log mani (xenocron)
Whats up Chris....I believe thats what he is saying, but he also said to get a ramhorn and it will solve my problem. I know that a lot of people are running the spoolin log getting over 400 with the same mods as me though. Dont feel like dropping another grand just to be able to boost more. I didnt think an SC34 would have a problem making over 12...on my last mani it make 14. I switched manis because i wanted to get to arouns 18psi, but ended up spending more money to make less power
Old Jan 13, 2008 | 02:25 PM
AWDstylez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed94 &raquo;</TD></TR><TR><TD CLASS="quote">Whats up Chris....I believe thats what he is saying, but he also said to get a ramhorn and it will solve my problem.</TD></TR></TABLE>
That doesn't even make sense. I'd say your boost issue is something else (boost leak or pre-turbo exhaust leak) and your other issue is the tuner. Get a new one.
However, is there any reason you went with a log on a B-series? Seems like a waste of a solid setup.
Old Jan 13, 2008 | 05:24 PM
JDMs1eeper's Avatar
unplug the wastegate vac so it doesnt seen boost. watch boost gauge to make sure you dont over boost but check to see if it "will" boost more then what he is saying.
My bet is, the manifold is fine and the tuner might be broken and need to be changed. lol
Check for exhaust or boost leaks. if boost is an issue still
Old Jan 13, 2008 | 06:08 PM
93CX's Avatar
Default Re: Problem boositng with Spoolin log mani (JDMs1eeper)
Sounds like BS, I'm going to make well over 320 on my Spoolin log combo
Old Jan 13, 2008 | 08:36 PM
patrick4588's Avatar
are you running a dumptube on the wastegate? without a dumptube it can cause excess exhaust in the engine bay essentially making it where no useable oxygen is pulled into the motor
Old Jan 14, 2008 | 06:58 AM
Speed94's Avatar
Default Re: (patrick4588)
Yes...running a dumptube on the gate
Old Jan 14, 2008 | 06:59 AM
Speed94's Avatar
Default Re: Problem boositng with Spoolin log mani (AWDstylez)
I wasnt looking for extreme hp...I was just looking to get to 400 or so and Ive read about people using a log and making that kind of power and more.
Old Jan 14, 2008 | 07:07 AM
nowtype's Avatar
You have a leak post compressor or your EBC is broken. What you are talking about is not a manifold issue.
Old Jan 14, 2008 | 07:13 AM
Speed94's Avatar
Default Re: Problem boositng with Spoolin log mani (nowtype)
How do you check the ebc?
Old Jan 14, 2008 | 07:15 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed94 &raquo;</TD></TR><TR><TD CLASS="quote">How do you check the ebc?</TD></TR></TABLE>
Try an manual one in its place to see if it fixes the issues
nowtype's Avatar
Acquire a MBC from a friend/eBay/where ever and see if running a simple MBC fixes the problem. If it does, then the EBC is the issue.
Old Jan 14, 2008 | 07:16 AM
AWDstylez's Avatar
Someone told you already. Disconnect the boost source from the wastegate and CAREFULLY roll on in 3rd gear and see if you can get more boost. If it still doesn't boost enough, you have a leak issue.
Old Jan 14, 2008 | 08:54 AM
B18C1CYA's Avatar
what size spring is in your wastegate ??
Old Jan 14, 2008 | 06:39 PM
you can only run about twice the psi that your spring is. so if you only have like a 5 or 6 psi spring in it, then that could be why
Old Jan 15, 2008 | 05:50 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 &raquo;</TD></TR><TR><TD CLASS="quote">you can only run about twice the psi that your spring is. so if you only have like a 5 or 6 psi spring in it, then that could be why</TD></TR></TABLE>
You can only run approx twice with a MANUAL boost controller...with a proper EBC you can run up to 4 times the spring, give or take.
Old Jan 15, 2008 | 06:59 PM
JDMs1eeper's Avatar
Default Re: (xenocron)
yeah, the max i could run with my 7psi spring was 27psi. Held steady for years.
Old Jan 15, 2008 | 08:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">
You can only run approx twice with a MANUAL boost controller...with a proper EBC you can run up to 4 times the spring, give or take.</TD></TR></TABLE>
oh. well i have a piston actuated wastegate, so i didnt know. just tryin to help
Modified by patrick4588 at 1:42 PM 1/16/2008
Old Jan 16, 2008 | 09:27 AM
Speed94's Avatar
I don't know what spring is in there to be honest. I know the tuner changed it once it got there though. I dont think he would oversee the spring as the reason why it wont go higher...plus it drops when it gets to 12...it wont hold there or go higher
Old Jan 16, 2008 | 09:43 AM
do a boost leak test. with the car off, hook up an air compressor to the compressor side of the turbo and put like 20psi through the system. if there are any leaks, all the excess air will blow out. its easy to hear and pinpoint that way
pamitar101
Sep 27, 2014 03:08 PM
Listerofsmeg
Mar 23, 2012 01:11 AM
Integra Type-GSR
Jul 7, 2011 05:17 AM
all_motoref9
Jul 7, 2004 11:42 AM
BoOsTiN Dc2
Mar 29, 2004 10:58 PM
