head work really needed?
Old Jan 9, 2008 | 05:56 AM
kenny7231's Avatar
Default head work really needed?
plan on rebuilding my motor soon, here the parts im getting ready to order.
wiseco piston
eagle rods
acl bearing
oem gaskets
my question is upgrading valve train and mild port job worth the extra money?
Old Jan 9, 2008 | 05:59 AM
kenny7231's Avatar
forgot to include power goal is about 300whp.. just want a reliable daily driver
Old Jan 9, 2008 | 06:07 AM
cjordan's Avatar
Default Re: (kenny7231)
headwork always helps on a boosted car in my opinion. For your power goals though, I would maybe just do a mild port job and like a 3 angle valve job. When I was making 329whp on my first turbo setup that's all I had done.
Old Jan 9, 2008 | 06:10 AM
kenny7231's Avatar
stock head should be ok correct?
Old Jan 9, 2008 | 06:47 AM
sp00led's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenny7231 &raquo;</TD></TR><TR><TD CLASS="quote">stock head should be ok correct? </TD></TR></TABLE>
Most definantly. I'd upgrade the valvetrain because I really enjoy spinning mine to 9k-10k rpm.
We are talking about a vtec head right?
Old Jan 9, 2008 | 06:59 AM
simply's Avatar
Default Re: (sp00led)
9k-10k rpm
Are you making power up there?
Old Jan 9, 2008 | 07:02 AM
kenny7231's Avatar
Default Re: (simply)
welll yeh motor is b18c1 and i plan on doing turbo down the road....
Old Jan 9, 2008 | 07:31 AM
SpoolnG2's Avatar
No, its definately not necessary for 300whp. It would be nice to do some springs and retainers like the guy from above said. Just to be able to rev it a little higher once your turbo.
Old Jan 9, 2008 | 07:35 AM
Turbo-LS's Avatar
Default Re: head work really needed? (kenny7231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenny7231 &raquo;</TD></TR><TR><TD CLASS="quote">plan on rebuilding my motor soon, here the parts im getting ready to order.
wiseco piston
eagle rods
acl bearing
oem gaskets
No head work what so ever is needed for 300whp. Dual springs you can do but not nessesary at all. Im running ctr cams with stock gsr valve springs to 8200 on 16 psi boost with no issues at all. stick with all stock if your goals are low. Keeps cost down and reliablity up. Thats my opinion anyhow
Old Jan 9, 2008 | 09:57 AM
sp00led's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simply &raquo;</TD></TR><TR><TD CLASS="quote">9k-10k rpm
Are you making power up there?</TD></TR></TABLE>
Peak HP is around 7800 but i'm still making over 500whp at 9000rpm. I don't ring it that high every day its only there when i need it. rev limter is set at 9400 but the motor has seen 10000 before.
Old Jan 9, 2008 | 10:47 AM
Boner_Ben's Avatar
I'd throw some valvetrain in it. Stock port heads are good for a ton of power.
Old Jan 9, 2008 | 11:39 AM
PHDZINE's Avatar
You think Honda's can't make power up there?
Modified by PHDZINE at 2:23 PM 1/9/2008
Old Jan 9, 2008 | 11:46 AM
HighRevn's Avatar
Default Re: (Boner_Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">I'd throw some valvetrain in it. Stock port heads are good for a ton of power.</TD></TR></TABLE>Dual valve Springs and retainers if you have the means.
Old Jan 9, 2008 | 03:40 PM
tealegg's Avatar
Default Re: (HighRevn)
well i made 305 at 7 psi on my gsr with b16 pistons and a blox intake manifold. tuned by me on hondata s200b. everything was OEM honda. it was my daily driver all summer and fall.
Jun 14, 2006 02:22 PM
Mr.DC2TurBo
Dec 28, 2004 06:27 PM
HEAD
Honda S2000
Jul 16, 2004 03:02 PM
RedTegLS
Mar 20, 2004 09:03 AM
Dr Drew
May 9, 2003 02:10 AM
