adjusting wastegate pressure
Old Jan 7, 2008 | 12:06 PM
Funanin's Avatar
Default adjusting wastegate pressure
I am new to the turbo scene, but not to motors, so I am installing my turbo kit on my civic D16Z6 and wondered which way or how to adjust the wastegate to lower the boost down to practically nothing for the first start up. It was sent to me with it set at 7 psi. Do I just turn the screw on the top counterclockwise?
Old Jan 7, 2008 | 12:40 PM
LastGenEK's Avatar
Default Re: adjusting wastegate pressure (Funanin)
So im assuming you have a external wastegate, you wont have to lower your boost, just dont put your foot in it too bad. 7lbs isnt to harsh on any motor anyways (like everyone says tune it) good luck
Post your setup if you want more feedback
Old Jan 7, 2008 | 02:20 PM
Funanin's Avatar
so the wastegate cant really be adjusted? or is it easier to just get a manual boost controller for like 50 bucks and call it a day?
Old Jan 7, 2008 | 02:44 PM
blwn95civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Funanin &raquo;</TD></TR><TR><TD CLASS="quote">I am new to the turbo scene, but not to motors, so I am installing my turbo kit on my civic D16Z6 and wondered which way or how to adjust the wastegate to lower the boost down to practically nothing for the first start up. It was sent to me with it set at 7 psi. Do I just turn the screw on the top counterclockwise?</TD></TR></TABLE>
but u have a twin turbo 302?
oh and btw, the car wont build boost while at idle so u can do the intitial start up without having to worry about running lean. Just dont go revving it to 6k
i'd just start the car and let it get warm a few times then trailor it to get it tuned good luck
Old Jan 7, 2008 | 04:52 PM
Funanin's Avatar
Default Re: adjusting wastegate pressure (trav95civic)
haha yes, i bought the turbo kit for it, but havent put it on yet... I have 2 motors for the mustang, the one in it right now is only a 302 that I run nitrous on... Meanwhile I am buildling up a 306 with all forged internals, and had it fully balanced at machine ship +/- 1 gram so it can spin up to 7k easy. That is what I am putting the twin turbo kit on once it is done. Meanwhile im getting my turbo "career" started with the civic and learning the ropes.
Old Jan 7, 2008 | 10:18 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Funanin &raquo;</TD></TR><TR><TD CLASS="quote">Meanwhile I am buildling up a 306 with all forged internals, and had it fully balanced at machine ship +/- 1 gram so it can spin up to 7k easy. </TD></TR></TABLE>
oh man this is so the wrong place to brag about a 7000rpm redline , and as everybody said dont worry about initial start up the turbo wont boost at idle, also a boost controller CAN NOT reduce boost below spring pressure, it can only raise it. good luck with the build...
Old Jan 8, 2008 | 02:56 AM
DaveF's Avatar
Default Re: adjusting wastegate pressure (blinx9900)
the turbo will not build boost @ an idle.
you can also drive the car(non erratic) and not go into boost......
Old Jan 8, 2008 | 04:19 AM
Funanin's Avatar
haha well yea i know i know, but 7k is alot for a ford V8, considering stock fuel shut off is 6250. But thanks for the comments guys
Old Jan 8, 2008 | 04:53 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Funanin &raquo;</TD></TR><TR><TD CLASS="quote">haha well yea i know i know, but 7k is alot for a ford V8, considering stock fuel shut off is 6250. But thanks for the comments guys</TD></TR></TABLE>
not really, the dirt track cars are turning damn near 8k or higher. Nascar- 10k
prostock drag car i would imagine can turn some rpms as well.
Old Jan 8, 2008 | 04:55 AM
Funanin's Avatar
Default Re: adjusting wastegate pressure (DaveF)
well yea, but we are refering to a street car, on a street car budget. Thats why I said it.
Also, so I guess what i am looking for now is how do I adjust the spring rate in the wastegate to be less?
Old Jan 8, 2008 | 05:20 AM
DaveF's Avatar
you cant adjust the spring to have less "pressure"...
you have to buy a new spring.
Old Jan 9, 2008 | 11:10 PM
welfarepc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">you cant adjust the spring to have less "pressure"...
you have to buy a new spring. </TD></TR></TABLE>
cut the spring.
this thread needs more
Old Jan 10, 2008 | 02:30 AM
DaveF's Avatar
Default Re: adjusting wastegate pressure (welfarepc)
thats ghetto, then your spring is too short and your wg is open probably all the time... what a waste.
Old Jan 10, 2008 | 05:51 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">thats ghetto, then your spring is too short and your wg is open probably all the time... what a waste. </TD></TR></TABLE>
x2
Cutting the spring would be a really bad idea.
avotegra
Nov 16, 2007 03:09 PM
Mag00n
Jun 26, 2006 09:36 PM
blackcivic44
Feb 1, 2005 07:45 PM
hatchracer02
Jan 10, 2005 05:13 AM
JDMs1eeper
Jan 9, 2004 02:31 PM
