injectors size
Old Jan 7, 2008 | 11:32 AM
B6teen's Avatar
Default injectors size
hey guys im getting a good deal on some injectors venom 650's anyone heard about them? and will 650's be good for 400 hp? i searched and only really found injectors for sale. thanks
Old Jan 7, 2008 | 12:04 PM
Schister66's Avatar
Man U FTW
650cc injectors will be fine...the general rule for injector sizing is as 6cc of injector per wheel horsepower while keeping the injectors at a reasonable duty cycle. If you want to run E85 instead of 91-94 octane, a conversion factor of 1.25-1.3 needs to be added.
650cc x 4inj = 2600 cc
2600 / 6cc (per hp) = 433 whp
Old Jan 7, 2008 | 01:33 PM
carzntune's Avatar
Default Re: (Schister66)
I have 750cc injectors (stock fuel pressure) at 375whp. New setup is gonna push 400-450 and nobody I've contacted recommends I keep the 750's. That being said, I would be skeptical on 650's for 400whp.
Old Jan 7, 2008 | 03:18 PM
Scheizty's Avatar
Default Re: injectors size (B6teen)
The injectors should be enough, but you will also need a larger fuel pump, fpr and should consider a bigger fuel rail. If you can't maintain high enough fuel pressure, then you will not be reaching your 400 hp goal.
Old Jan 7, 2008 | 03:32 PM
blwn95civic's Avatar
Default Re: injectors size (Scheizty)
like stated above 650's will work fine but i'd go with a larger injector just for down the road if u ever want to get more power out of your setup, ive got a set of rc 750's for my 400whp setup
Old Jan 7, 2008 | 06:21 PM
B6teen's Avatar
Default Re: injectors size (trav95civic)
thanks for the replies and input. does a 255 pump aem fpr and rail sound good?thanks again
Old Jan 7, 2008 | 06:24 PM
H.A.R.T B18C1EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B6teen &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies and input. does a 255 pump aem fpr and rail sound good?thanks again
yup i was running walbro 255, stock rails, and a aem FPR and made 440whp with ease
Old Jan 7, 2008 | 07:46 PM
Schister66's Avatar
Man U FTW
Default Re: (carzntune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carzntune &raquo;</TD></TR><TR><TD CLASS="quote">I have 750cc injectors (stock fuel pressure) at 375whp. New setup is gonna push 400-450 and nobody I've contacted recommends I keep the 750's. That being said, I would be skeptical on 650's for 400whp.</TD></TR></TABLE>
I'll do the math for you once again just to prove its fine.
<u>My Car</u>
Using RC550s and making 315whp with low duty cycle
550cc x 4cyl = 2200cc
2200cc / 6cc (per whp) = 367whp with ~75-85% duty cycle
<u>Your Setup</u>
750cc x 4cyl = 3000cc
3000cc / 6cc (per whp) = 500whp with ~75-85% duty cycle
Therefore, whoever told you that you wont have enough injector was sadly mistaken.
Old Jan 7, 2008 | 08:09 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">I'll do the math for you once again just to prove its fine.
My Car
Your Setup
Therefore, whoever told you that you wont have enough injector was sadly mistaken. </TD></TR></TABLE>
Modified by mtber at 12:28 AM 1/8/2008
Old Jan 8, 2008 | 06:53 PM
B6teen's Avatar
Default Re: injectors size (H.A.R.T B18C1EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 &raquo;</TD></TR><TR><TD CLASS="quote">
yup i was running walbro 255, stock rails, and a aem FPR and made 440whp with ease</TD></TR></TABLE>
what size injectors? are venom injectors any good?
Old Jan 8, 2008 | 07:46 PM
Schister66's Avatar
Man U FTW
what size injectors? are venom injectors any good?</TD></TR></TABLE>
The 650s should be fine. I'm not sure about Venom injectors. I personally would use either RC or PTE
EGed up from the seat up
17
Jul 2, 2009 12:16 AM
Briyumbero
Nov 13, 2008 05:24 AM
lskid98
Mar 4, 2008 06:50 PM
S2KP
Jul 2, 2004 10:28 PM
boosted3g
Sep 1, 2003 06:17 AM
