can you but a t3 turbine housing on a t4 t61 turbo?
as title says. its a Turbonetics T61 Ceramic Ball Bearing (CHRA) Turbocharger. has the O-Trim Compressor with a 0.58 AR. T4 flange on the input, and a 3" band connection on the out well? if not do you think i could run a turbo as is like this a fully built 84mm nonvtec 4cyl? thank you
Re: can you but a t3 turbine housing on a t4 t61 turbo? (Prelude91siT)
you should be able to find a housing in the t3 frame you are looking for.
i do belive you will be fine with the t4 housing though...
fwiw, my t4/74mm turbo on the racecar spooled faster and made more power all over the plot, then my t3/67mm turbo did on my street car. (both on the same exact engine)
i thougth the biggest t3 housing u can get is a N-trim and thats the same as an stage-5 wheel, and if it had any bigger bore it would touch the bolts holes in the t3 housing
they had a custom bore p-trim for a t3 housing forgot about that
