NOS Suggestions??
Old Jan 12, 2008 | 07:14 PM
RWD-Integra_TeamKO's Avatar
Default NOS Suggestions??
I have a GSR motor over bored to 2.0 Type R Pistons Currently Boosted JRSC about 8 lbs. now at 207rwhp. I plan to add a 4 jet wet kit....any suggestions on a safe shot limit?
Old Jan 12, 2008 | 07:30 PM
racebum's Avatar
Default Re: NOS Suggestions?? (RWD-Integra_TeamKO)
Get your car on a dyno and test the nitrous there, make sure your A/F at WOT is where it should be. The last motor i played around with that used nitrous was a LS1, with the A/F around 12.5-1 that motor took some serious abuse. People who let it go lean quickly break rings and detonate pistons. start with a 50 and go from there. Generally things get more touchy when you start trying to go past 50% of NA power.
Old Jan 12, 2008 | 07:32 PM
Dogginator's Avatar
Daisy... Daisy...
Before anyone flames, he meant rwhp in this case.
Old Jan 12, 2008 | 07:46 PM
racebum's Avatar
Default Re: NOS Suggestions?? (Dogginator)
you mean fwhp? i wasn't going to even mention it but GSR's have a hard time with Rear Wheel HorsePower
Old Jan 13, 2008 | 05:37 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: NOS Suggestions?? (idrivesideways)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idrivesideways &raquo;</TD></TR><TR><TD CLASS="quote">you mean fwhp? i wasn't going to even mention it but GSR's have a hard time with Rear Wheel HorsePower</TD></TR></TABLE>
Not the OP's car. It is the Braille Auto 4wd Rwd Integra. The question is still applicable to the normal FWD setup.
OP, you should ask this in the forced induction section as well.
Old Jan 13, 2008 | 07:55 AM
LoseRPunKx182's Avatar
look at the OPs name, whatever drivetrain shouldn't matter tho, i hope i get a chance to see it
i have thought about nitrous a couple times but im not going to go that route just because even with any jet, small or big, i would tune it and when u are not spraying you're a/f would be running richer than optimal with just the jrsc. if i would have to recommend a safe limit i would say 50-100 but the 2.0 and type-r pistons scare me.
Old Jan 13, 2008 | 09:57 AM
racebum's Avatar
Default Re: NOS Suggestions?? (LoseRPunKx182)
No kidding, i've never heard of these things, i need to google this. that's just plain bad *** !
Old Jan 15, 2008 | 07:10 PM
Sorry trial user only 5 posts in a 24 hour!!!! JESUS!!!
RWD Integra
http://www.teamko.net
once its fully modified it won't easily go back to 4wd.... but its need to turn it into a drifting machine...
I was planning on a 75 shot for the car. I will stick with that.
cleanej2
15
Nov 5, 2006 02:05 PM
JWHATCH23
Oct 6, 2006 12:47 PM
IntegraGSR(-1)
May 18, 2006 08:26 AM
Modifiedinteg
Nov 27, 2003 05:27 PM
EEK
Jun 4, 2002 09:01 AM
