low compression??
Old Jan 12, 2008 | 03:20 PM
B18C-YA!'s Avatar
Default low compression??
hey guys, I have a JDM GSR B18C 10.6:1 compression that was turboed not to long ago but the kit was pulled off and im currently runnin NA with plans of turboing again within the next month... but my question is, i did a compression test on it a couple days ago and it was 180 across the board. isnt that a little low? i was kinda expecting closer to the lower 200's
thanks
Old Jan 12, 2008 | 04:15 PM
Schister66's Avatar
Man U FTW
It could be the error in the gauge. The most important aspect is that all cylinders are within a few psi of each other.
Old Jan 13, 2008 | 08:04 AM
B18C-YA!'s Avatar
Default Re: (Schister66)
yea they were all exactly 180
Old Jan 13, 2008 | 01:21 PM
Schister66's Avatar
Man U FTW
Then i wouldnt be too worried about it...
Old Jan 13, 2008 | 03:46 PM
HiProfile's Avatar
When I checked my d16z6 (stock) before a valve adjustment & turbo'ing it, it was 210 across the board with a snap-on comp tester. It had stock pistons & never resurfaced, so that should say how gauges compair.
As long as the readings between cylinders is w/in 5%, you're good. The chances of having all the rings bad and give the exact same reading is the same as seeing a 300lb girl on that Top Model show.
Old Jan 14, 2008 | 02:07 AM
B18C-YA!'s Avatar
Default Re: (HiProfile)
lol thanks for the help guys
EARLdaSQUIRREL
Nov 25, 2006 07:05 PM
Z32Z06
Honda S2000
Feb 8, 2006 04:59 PM
kornerk12
Jan 5, 2006 07:20 PM
Cyber ITR
Aug 2, 2002 09:28 PM
