Noob trying to get turbo Kit. Befor getting a Turbo Kit, What do I need?
Im trying to gert a turbo kit on my 05 Accord coupe EX 4cyl with 5spd man.
I found this turbo kit from online.
http://www.sportcompactonly.co...0.htm
is this turbo kit is good?
and, before I buy this turbo kit, do I need to have bolts on?
Also, Any special mode to put turbo kit?
Most bolt ons will not be compatible with a turbo set up. Any intakes/headers/and most NA exhausts will just have to be replaced.
The only thing I can think of doing before ordering a kit would be to get a compression and leak down test done to make sure the engine is healthy.
Re: Noob trying to get turbo Kit. Befor getting a Turbo Kit, What do I need? (xkrntamax)
you need to do alot of reading.
kits are a waste of money.
you can piece together your own and it'll cost alot less than the kits with extra to do whatever you want. you can find everything you need to know...
https://honda-tech.com/zerothread/1024174
Re: Noob trying to get turbo Kit. Befor getting a Turbo Kit, What do I need? (92civicx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicx »</TD></TR><TR><TD CLASS="quote">you need to do alot of reading.</TD></TR></TABLE>
Research and do it right the first time
Re: (carrnut21)
"Turbo Specialties Superior Turbo Kit"
that is the name of the kit for my 05 accord EX coupe 4cyl.
I dont know much about the turbo, thats the reason I am trying to get a kit.
So I need all bolts on that will comptible for turbo, and compression and leak thingy?
Re: (xkrntamax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkrntamax »</TD></TR><TR><TD CLASS="quote">So I need all bolts on that will comptible for turbo, and compression and leak thingy?
Very well put.
Read the suggested link above and this one also. You gotta do some reading and searching, bud... https://honda-tech.com/zerothread?id=2110370
Very well put.
