Help I need 9:1 compression!!!
Old Jan 2, 2008 | 09:38 PM
bootlegcivic's Avatar
Default Help I need 9:1 compression!!!
Alright here's the setup B16B head and block with a LS crank and LS rods (to convert to 1.8). Do I use 9:1 LS pistons or 9:1 b16 pistons to get the compression I want? I'm confused on wrist pin placement and combustion chamber size with the B16b head.
Any more info needed on the setup let me know.
Old Jan 3, 2008 | 02:19 AM
wakedoe's Avatar
Default Re: Help I need 9:1 compression!!! (bootlegcivic)
Well the B16B is the same height as the B18 so you'd treat it as an LS/Vtak. So LS 9:1 pistons should yield a slightly higher compression, something like 9.1:1 or 9.2:1, but B16 9:1 pistons will probably put you at 9.8:1 or 9.9:1. Compression ratio is the volume of the cylinder+volume of combustion chamber over volume of combustion chamber, and a B18B crank has a much longer stroke, so you it would be compressing a much larger air/fuel mix into the same space.
Old Jan 3, 2008 | 05:21 PM
Default Re: Help I need 9:1 compression!!! (wakedoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakedoe &raquo;</TD></TR><TR><TD CLASS="quote">Well the B16B is the same height as the B18 so you'd treat it as an LS/Vtak. So LS 9:1 pistons should yield a slightly higher compression, something like 9.1:1 or 9.2:1, but B16 9:1 pistons will probably put you at 9.8:1 or 9.9:1. Compression ratio is the volume of the cylinder+volume of combustion chamber over volume of combustion chamber, and a B18B crank has a much longer stroke, so you it would be compressing a much larger air/fuel mix into the same space.</TD></TR></TABLE>
anyone else confirm this?
Old Jan 11, 2008 | 11:13 PM
bump
Old Jan 11, 2008 | 11:49 PM
Mfoehrkolb's Avatar
http://www.clubcivicquebec.com...f.php
--- I agree with what he says, just look @ that site. Do your set up and look @ comp you get.
I was gonna use pr3 pistons on my lsV setup but thanks to this site i decided no. I was gonna yield almost 13:1 comp haha. WAY to high for what i want.
hioutput
Jun 13, 2005 11:53 AM
GDM Z28
Aug 29, 2004 09:23 AM
JDM 007
Jan 24, 2003 01:08 PM
JDM 007
Jan 24, 2003 01:07 PM
