tuning with open wastegate
Old Jan 3, 2008 | 06:17 PM
Peter Brady onlyonweekndz's Avatar
Default tuning with open wastegate
i was wanting to know if this has any effect at all on your a/f ratios...i have a drag manifold and u would think that exhaust gas going into atmosphere would not be read by o2 sensor, in turn giving inaccurate a/f.... idk, i just wanted to see what some opinions were cause i searched and found nothing..
Old Jan 3, 2008 | 06:34 PM
melovesboost's Avatar
I imagine it would have a effect with tunning cause the open wastegate is just going to be dumping Dirty air right back into the path of the turbo and the turbo is just going to suck the dirty air back in.
Not to mention it will make your engine bay filthy.
Old Jan 3, 2008 | 06:47 PM
inspector01's Avatar
Were you planning on putting a WBO2 sensor in your dump tube too?? Cuz otherwise open wg will be the same as having a dumptube with reading your AFR, and only some of your exhaust goes out the wg, not all so your wideband still reads. But yes, it can get the exhaust sucked back into the intake or make it dirty, but i am not running a dumptube now and i know other ppl that have done that with 10 second cars no problems.
Old Jan 3, 2008 | 06:59 PM
Default Re: (inspector01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspector01 &raquo;</TD></TR><TR><TD CLASS="quote">Were you planning on putting a WBO2 sensor in your dump tube too?? Cuz otherwise open wg will be the same as having a dumptube with reading your AFR, and only some of your exhaust goes out the wg, not all so your wideband still reads. But yes, it can get the exhaust sucked back into the intake or make it dirty, but i am not running a dumptube now and i know other ppl that have done that with 10 second cars no problems.</TD></TR></TABLE>
Ya that is true. but more power can be found simply by routing a dumptube out of the way of the intake
Old Jan 3, 2008 | 09:12 PM
Default Re: (melovesboost)
what i meant was, does the exhaust that escapes have any effect on the exhaust going to the wideband?
Old Jan 3, 2008 | 11:11 PM
welfarepc's Avatar
you have a river... the river has a fork in it
is the water on the right the same as the water on the left? yes
now im not sure about a divided manifold style setup...
Old Jan 4, 2008 | 06:39 AM
homemadeturbo's Avatar
Default Re: (welfarepc)
Bottom line is it will work fine. Plenty of people have been doing it for over a decade now.
The exhaust gas composition isn't going to change at all when you are all full boost dumping your wastegate to atmosphere. Say you have 5% O2 in your exhaust (hypothetical). You hit full boost and some of the gas is bypassing the turbo/exhaust and exiting to atmosphere. This ejected has has the same composition as the gas going through your exhaust, and won't change the reading from your wideband any significant amount.
Old Jan 4, 2008 | 07:44 AM
.CUBISH.'s Avatar
Default Re: (homemadeturbo)
it will run fine......as long as you have the wastegate dumping well away from the turbo inlet... ive seen 80+hp gains on cars that didnt have a good blowdown tube on it...turbo is pretty much sucking in exhaust gases
Old Jan 4, 2008 | 08:01 AM
cjordan's Avatar
Default Re: tuning with open wastegate (Peter Brady onlyonweekndz)
I know when we were tuning my car we were not getting the numbers we expected to begin with. After some time consuming troublshooting we determined my turbo was sucking up a ton of hot dirty air out of the wastegate and we routed a dumptube to about the same height as the bottom of the oil pan. Next pass saw a significant gain in power.
Old Jan 4, 2008 | 10:54 PM
Default Re: tuning with open wastegate (cjordan)
thats pretty interesting..mine was a little past my oil pan so i didnt have any probs...i think this time i will try to run it under the engine so it wont be so loud..thanks for the info!
Old Dec 3, 2010 | 05:33 PM
newtob18's Avatar
Im running really rich with a FMU and 12:1 disc and it's dumping rich soot out of the wastegate and it seems like my boost has substantially diminished. If I turn the wastegate over and have it point down instead of up will that help or do I defientely need a dump tube from the wastegate to under the car? Also, can a wastegate get plugged from the rich condition?
Old Dec 3, 2010 | 10:25 PM
DUDMD's Avatar
The wideband o2 measures the ratio of gas/oxygen particles, not volume. So as long as there are no new elements introduced into the exhaust, the ratio will not change. Wastegate is only open under boost pressure, that means the pressure of the exhaust gasses is also rising and flow, and there is no physical way that the fresh oxygen can get back into the manifold through the wastegate/dumptube and be read by the o2.
Just my .02
fcluddington
Engine Management and Tuning
Apr 7, 2011 04:54 AM
Alucard-1524
Aug 3, 2010 01:13 PM
Bizarre
Jul 9, 2007 02:17 PM
crispydee
May 26, 2005 10:36 PM
Integra808
Apr 3, 2003 06:08 PM
