Running 3" exhaust under the rear susp.
So im just tryin to find pics and info on doin this. I wanna run a real simple exhaust setup thats gonna be V-Band'd. But i wanna run it under the rear suspension. I know its gonna decrease ground clearance but is it really that bad? Anyonewith pics or info on this, please post up.
For reference
Hope its ok to use the pic, if not, ill take it down.
For reference
1 Post
Re: Running 3" exhaust under the rear susp. (a1320honda)
yes its bad if it scrapes and gets dented up
yes its good because there are less bends and it will make more power
my evo as like all evos have the exhaust routed under the suspension. there are almost no bends and there is a ton of clearance
but will all the hondas i see this done i think it hangs way to low for a street driver lower honda
Re: (2point2)
Mine goes under the gas tank. For a race car it's fine, but i wouldn't do it on a street car. I have about 3-4" of ground clearance with 4" exhaust going under the tank, but i dented the tank up a little too.
ill be doing the saem thing....look into oval exhaust tubing gives the same cfm as a 3IN.. http://www.drgas.com/store/home.php?cat=8
give a good refrence to size from circle to oval....this is waht my setup will be gogin as..
Re: (full Circling)
As long as the cross sectional area doesnt change or change significantly in a short distance there will be *negligible* affects on velocity.
Re: (full Circling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by full Circling »</TD></TR><TR><TD CLASS="quote">^damn, now that's a good idea!
anyone know if using oval tubing over round would affect exhaust velocity?</TD></TR></TABLE>
youd want the whole length of tubing to be oval though, otherwise youd have a slight bottleneck when making the transition from round to oval.
Re: (usdm97DC4)
Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 »</TD></TR><TR><TD CLASS="quote">what would you do then as far as the flange from the circular downpipe to the oval tubing?</TD></TR></TABLE>
Burnsstainless makes transitions. I'm using two on my setup.
Re: Running 3" exhaust under the rear susp. (4thgenhtch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenhtch »</TD></TR><TR><TD CLASS="quote">/\/\ That looks fun to drive on the street </TD></TR></TABLE>
it was actually driven every day to and from work.
i ♥ my honda
Global Mod
Global Mod
Re: Running 3" exhaust under the rear susp. (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">you guys are queers.
I ran it right under the gas tank.
HAHA no way I could get away with that around here. That's like less then an inch of clearance.
If you get were the lowest point is where the rear subframe is at then it is not such a big deal. Because, if you hit the bump straight, then both wheels will go over it and it should clear. Dips on the other hand, are a whole different story
Re: (Riake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riake »</TD></TR><TR><TD CLASS="quote">If you get were the lowest point is where the rear subframe is at then it is not such a big deal. Because, if you hit the bump straight, then both wheels will go over it and it should clear. Dips on the other hand, are a whole different story</TD></TR></TABLE>
exactly. it hangs a little bit lower than the subframe which is more than enough clearance for most places.
Re: (punkracer)
i ran mine unther the gas tank cause i wanted it to be as straight and free flowing as possible. it clears good enough for me. if i get it up on the lift ill take a pic and post it here.
