nitrous Q
Old Jan 8, 2008 | 07:02 PM
''Simon'''s Avatar
Default nitrous Q
im going to spray a 50 or mabye a 75 shot on my stock b16. i have a vafc. i was wonder wich shot to use.and if ishould add some feul or what it is a dry kit. ive use a wet kit and no how to do it that way, but i have never messed with a dry kit. just dont to mess my car up. thanks for the inputs.
Old Jan 8, 2008 | 07:58 PM
Joseph Davis's Avatar
Default Re: nitrous Q (''Simon'')
Get a wet kit. Your possession of a VAFC has nothing to do with this, and frankly your mention of it scares me.
Old Jan 8, 2008 | 08:04 PM
Schister66's Avatar
Man U FTW
Default Re: nitrous Q (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote"> Your possession of a VAFC has nothing to do with this, and frankly your mention of it scares me.</TD></TR></TABLE>
lol...nothing like old technology
Old Jan 8, 2008 | 08:12 PM
kdawgy2k1's Avatar
Honestly, the correct way to test out a dry shot is to start with the smallest you can get and put it on a dyno and or get a wideband... Adjust your fuel pressure to about 44-46 psi... (thats if you have stock injectors and and OEM fuel pump... )
I ran a 60 shot on a 91 DA for 2 1/2 years everyday all day until i got greedy and tried to spray a 75 and the fuel pump couldnt pump out anymore and it ran a bit lean... I made another pass with an AFC just like in your case and it really didnt make that much of a diff cuz the pump was pretty much at 100% duty cycle...
I then swapped it out for an OEM ITR pump and it ran beautiful but again as we all know its only a matter of time before STOCK internals say buh-by!!!
I ended up cracking a ring land... but for 2 1/2 years and 140,000+ miles on pretty much stock B18a ( LS motor ) I made 184whp and 206wtq and that was SAE CORRECTED...
Good luck and dont short cut anything... always do it the right way and FIND A DYNO and progress slowly...
Old Jan 8, 2008 | 08:28 PM
''Simon'''s Avatar
Default Re: (kdawgy2k1)
im just useing this dry kit. i got it for free and i have had a wet kit before and had it running good. but wet had fuel added. im just worried about not having enuff fuel. it came with a 50 shot so im probly going to use that. if i use a fuel of 101 would i have to change the fuel pressure. or do u think it would be fine. and i said i had a afc cuz i need to no if i should just use that to add fuel or what to do.
89dxhunchback
Nov 6, 2005 09:04 PM
nevin
Feb 5, 2004 07:44 AM
Goldfingiz
Jun 26, 2003 05:20 AM
RTE117
Apr 29, 2003 04:59 PM
gsl_05
Aug 13, 2002 06:24 PM
