throttle BoDy Size !!!!!!!
Old Jan 6, 2008 | 05:55 PM
Kid_SiR's Avatar
Default throttle BoDy Size !!!!!!!
HEy Guys i was wonder is it worth get a 70 or 76mm throttle body in a victor X manifold i know that the victor x is good for 65 but if i get a 76 or 700 i gotta open it upp...
So the question Is it Worth getting A bigger throttle for turbo an stay with 65mm
Old Jan 6, 2008 | 06:07 PM
Boner_Ben's Avatar
Default Re: throttle BoDy Size !!!!!!! (Kid_SiR)
How much power are you looking to make? Personally I just like to have my throttlebody the same size as the intercooler pipe so I upgraded to a 74mm after I went with 3" piping. I have made almost 600 on a stock t-body though so just goes to show how non important they are.
Old Jan 6, 2008 | 06:12 PM
Kid_SiR's Avatar
Default Re: throttle BoDy Size !!!!!!! (Boner_Ben)
well im doign bout 425 with 2.5 pipin an my boi is doing 300 wat doo u think its better too stay 65 mm
Old Jan 6, 2008 | 06:15 PM
Boner_Ben's Avatar
You probably wont see any gains either way. If I was going to upgrade I'd probably go bigger and port the manifold to match.
Old Jan 6, 2008 | 06:27 PM
Schister66's Avatar
Man U FTW
If you have 2.5" IC piping, then get a throttle body that is similar if not slightly larger in diameter.
2.5in x 2.54cm/in = 6.35cm
6.35 cm x 10mm/cm = 63.5mm
Therefore get something about 64mm or slightly larger
CRXherbie91
Jul 28, 2010 04:48 PM
kte324
Feb 7, 2009 04:59 AM
B18Sleeper
Oct 24, 2005 09:20 AM
dunkd
Mar 5, 2005 01:12 AM
XES
Oct 16, 2004 07:22 AM
