help with lsvtec compression
Old Jan 10, 2008 | 04:14 AM
Chris Crane's Avatar
Default help with lsvtec compression
ok i have searched for an hour or so but no luck, i am currently building a 81.5mm lsvtec for boost and using wiseco pistons but they dont offer any to reach the 9.0 to 1 ratio that my tuner recommended for daily driving so could i get the 9.3-9.8 to 1 and do a multi layer head gasket (if so what one) or would it be better to get the 8.3-8.8 ones and mill the head??? i thought the head gasket would be the better one but im new to all this??? all im trying to do is get to 9.0 area
Old Jan 10, 2008 | 06:16 PM
Default Re: help with lsvtec compression (Chris Crane)
bump
Old Jan 10, 2008 | 06:34 PM
TheShodan's Avatar
Moderator
you can always use a different company piston that would be 9.0:1 like JE.
9.3-9.8 is just fine for a built motor LSVTEC Turbo. I do not recommend the 8.0:1, off boost response would seriously suffer depending upon the turbo used.
Old Jan 10, 2008 | 06:53 PM
Default Re: help with lsvtec compression (TheShodan)
thats what i was worried about was exactly what your talking about and i really rather run wiseco pistons, not that i want this to turn into a pissing match about what piston is god but me and my father have had good luck with his drag car and wisecos. also by built i didnt mean sleeved just all forged internals
Old Jan 10, 2008 | 07:38 PM
Outkast95LS's Avatar
I'm currently running the 8.3:1 Wiseco pistons in my 81.5mm LS-V build. The off-boost response isn't that bad IMO. In fact, the motor feels really similar to my old LS-T set up. I'm using the typical 57 trim t3/t4 turbo.. I think it ultimately comes down to what you and your tuner prefer as to which pistons you want to select. You can opt for the 9.3-9.8:1 pistons and don't necessarily have to get a thicker headgasket.
Old Jan 11, 2008 | 04:33 AM
Default Re: help with lsvtec compression (Outkast95LS)
but doesnt the vtec head add some points on a b18 block so it could possibly be anywhere from 9.5-10.1 to 1 couldnt it??
Old Jan 15, 2008 | 05:08 AM
anyone else have an opinion???
Old Jan 15, 2008 | 07:42 PM
jdmcoop's Avatar
You could run a 9.3:1 with a .040 head gasket and it should help drop it down to around 9.0:1.
Chris Crane
Mar 8, 2008 10:16 PM
NathanMorris
Jul 28, 2006 05:59 PM
PhatBoy5015
Mar 11, 2006 02:26 PM
pcguy760
Apr 23, 2005 12:04 AM
JM Performance
Nov 19, 2001 12:47 PM
