need help ls with srp pistons
Old Jan 8, 2008 | 04:54 PM
krazyturbo1's Avatar
Default need help ls with srp pistons
i have a b18a1 block with srp pistons i just tore the motor down and everything looked great the only question i have is there is a noticable gab between the piston and wall as far as i know the block was never bored out is this normal ??? the pistons due move in the sleeve should i be worried>>>motor never smoked ran great on boost any input would be great thanks
Old Jan 8, 2008 | 04:57 PM
DaveF's Avatar
Default Re: need help ls with srp pistons (krazyturbo1)
the piston will rock slightly in the bore, you should be able to move it with a slight push of the finger.
Old Jan 8, 2008 | 05:28 PM
Default Re: need help ls with srp pistons (DaveF)
thanks so it should be fine to rering and bearing then? i just got a lil concerned didnt want any problems after the build
Einhander276
Sep 10, 2012 10:04 PM
kyden
Jun 12, 2009 08:16 AM
krazyturbo1
Jan 8, 2008 07:22 PM
jamessh1
May 28, 2004 04:30 PM
Triple T
Jan 28, 2003 09:31 AM
